Loose driver's door
Old Jan 10, 2018 | 02:00 PM
MackGuy's Avatar
MackGuy
Loose driver's door
Strangely I couldn't find anything in this going through pages of search results. Maybe it's not a big issue.
I've noticed some clunking from driver's door going over large bumps etc. Also I've notices on uneven surfaces that there's quite a bit of movement between door and body
Seems like maybe the latch mechanism is worn. I didn't detect any looseness in the hinge area.
Has anyone had this problem and resolved it, or do I just need to get a new latch and post?
Old Jan 10, 2018 | 04:23 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I would suspect the door seal around the perimeter of the door is worn out. We are finding this to be the case on our Excursions over in the X forum. Members are replacing that rubber seal and yelling "Eureka!"
Old Jan 10, 2018 | 05:40 PM
MackGuy's Avatar
MackGuy
I do notice some wear on the seal, but assumed that was a symptom of the door moving not the cause. Still might be worth it.Is the seal common with f150, or unique to Expedition/Navigator?
Old Jan 10, 2018 | 06:36 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
F150 and Expy share same front door.
jlalanas
Mar 20, 2017 08:18 AM
caedo
Feb 10, 2014 08:51 AM
80s Trucker
Jun 20, 2010 09:54 PM
RidinHIGH
1978 - 1996 Big Bronco
Mar 24, 2005 04:13 PM
Mattias
Feb 1, 2003 04:27 AM
