Phone Mounts
Old Jan 10, 2018 | 09:02 PM
grege's Avatar
grege
Originally Posted by K A M
RAM Mount Tough-Track 7
#RAP-TRACK-A5U
SKU RAPTRACKA5
RAM Mount Plastic 1 inch Ball Track Base with T-Bolt
#RAP-B-354U-TRA1
SKU. RAPB354TRA1
Thanks for posting this. I'm looking for a T-Bolt to go in the back of a monitor. I like the one you posted better than the one I posted. I'll check the measurements tomorrow and see if it will work in my device.
Old Jan 10, 2018 | 09:10 PM
K A M's Avatar
K A M
They have different ball sizes for the T-Bolt. I just use the 1" for everything I have.
Old Jan 10, 2018 | 09:18 PM
roadpilot's Avatar
roadpilot
I don't use a phone mount in my new F350 (Android Auto gives me Google Maps, Waze, Pandora, reads my texts, makes my calls, etc.)., but in my last truck, I really liked the Nato Mount. Easy to install, easy to remove & reinstall/reposition, and the magnet & plate make it super easy to mount/dismount.
https://www.natomounts.com/
Old Jan 11, 2018 | 08:01 AM
grege's Avatar
grege
Yeah I plan on using 1" ***** too. I mounted one from my rear view mirror. Had to do a little modifying to get it to work since not much back there with the box. I was referring to the size of the t-bolt to make sure it will fit in the slit in the back of my monitor. I'm checking with RAM on a couple of their parts to see what the size is. I might have to do a little Dremel work to grind it down a bit to make it fit.
Old Jan 11, 2018 | 08:14 AM
K A M's Avatar
K A M
I had a gps on the mirror. I had it to the left and used a arm long enough to get it up off to the left of the mirror and up to ceiling. This way it is out of my line of sight and tucked up.
Old Jan 11, 2018 | 08:28 AM
grege's Avatar
grege
Nice. Since this is for a monitor for a backup camera on my camper I just plan on it covering my rear view mirror. Then when we are camping I can easily lower the monitor or remove it to use the rear view mirror again.
From what I heard back from Ram I think I will need to do a little grinding on the t-bolt.
66crawler
Mar 17, 2012 04:17 AM
DarrellJ
Nov 5, 2009 10:40 PM
EXOPAR
May 13, 2003 12:36 AM
fatdaddy
Jul 2, 2002 10:54 AM
DutchmanAZ
May 31, 2002 02:42 PM
