Phone Mounts
Old Jan 10, 2018 | 06:03 AM
diblasi's Avatar
diblasi
Phone Mounts
What mounts are you guys using?? Add some pics if possible.
Old Jan 10, 2018 | 07:14 AM
Poncho450's Avatar
Poncho450
Got this one at the beginning of October. So far so good. My only recommendation is to have your phone in some kind of case to stick the metal disc onto instead of directly to the phone. Mine's on a case and works just fine. Very good magnet unit.
I'm thinking of getting another for my skid steer.
Amazon Amazon
Old Jan 10, 2018 | 07:28 AM
Capt. Ted's Avatar
Capt. Ted
Steelies! I have only found them at TSC, and online.
www.ebay.com/i/331595846453?chn=ps
Old Jan 10, 2018 | 07:54 AM
Poncho450's Avatar
Poncho450
Looks like basically the same thing I bought, only a hell of a lot cheaper! No luck searching TSC website so far.
Old Jan 10, 2018 | 08:37 AM
diblasi's Avatar
diblasi
I have an iPhone 6+. Will this mount work for it. It looks like in add it's only up to iPhone 5
Old Jan 10, 2018 | 08:39 AM
diblasi's Avatar
diblasi
Also where did you guys actually mount it? Trying to figure out best place so charging cable is not in the way.
Old Jan 10, 2018 | 08:40 AM
Poncho450's Avatar
Poncho450
Search Amazon using "magnetic phone mount". You'll see all kind of models and price ranges. I've got this one in the cart right now, there's a discount on it for about another 14 minutes:
Amazon Amazon
Old Jan 10, 2018 | 08:50 AM
diblasi's Avatar
diblasi
https://www.amazon.com/gp/product/B0...2AD73GRY&psc=1
Kickass deal out the door 8.20 and primed be here in 2 days! Thank you sir!
Old Jan 10, 2018 | 08:57 AM
Poncho450's Avatar
Poncho450
Not sure if these would work for you, but I just ordered some of these ebay cheapies too.
https://www.ebay.com/itm/222755730987
Old Jan 10, 2018 | 09:08 AM
K A M's Avatar
K A M
Piece of scrap wood flooring to match the wood grain. Cut to fit so it's tucked under in the rear and under the sliding door in the front. Cut it to 3-3/4 in. X 9-7/8 in. Then cut a 1/4" out the rear to fit where the door slides into the console and agains so the sliding door can slide up over some to hold in place. Then cut 1-1/2" from the edge of the groove so the curvature of the door can come over. When cutting the wedges cut little at a time and test fit so you get a snug fit. Hard to explain. The door and slots is slightly curved and the wood is flat. Also cut a slot to pass the USB through. RAM rail base with T-Ball, short arm, X-Grip to fit. Small slot in rear for pass through for USB between door and wood. Works great. All can be removed in 5 seconds by push the sliding door fully open and removed wood bracket plate.
RAM Mount Tough-Track 7. (The next size larger is too long for the opening)
#RAP-TRACK-A5U
SKU RAPTRACKA5
RAM Mount Plastic 1 inch Ball Track Base with T-Bolt
#RAP-B-354U-TRA1
SKU. RAPB354TRA1
Old Jan 10, 2018 | 06:29 PM
glrret's Avatar
glrret
Originally Posted by K A M
Piece of scrap wood flooring to match the wood grain. Cut to fit so it's tucked under in the rear and under the sliding door in the front. RAM rail base with T-Ball, short arm, X-Grip to fit. Small slot in rear for pass through for USB between door and wood. Works great. All can be removed in 5 seconds by push the sliding door fully open and removed wood bracket plate.
K A M I fownd the rails but what it the part number for the T-Ball that you re showing?
Old Jan 10, 2018 | 07:10 PM
grege's Avatar
grege
Maybe this one?
https://www.amazon.com/gp/product/B0089TOM0I/ref=ox_sc_sfl_title_2?ie=UTF8&psc=1&smid=A2XENS8LQP1A6D https://www.amazon.com/gp/product/B0089TOM0I/ref=ox_sc_sfl_title_2?ie=UTF8&psc=1&smid=A2XENS8LQP1A6D
Old Jan 10, 2018 | 07:34 PM
K A M's Avatar
K A M
#RAP-TRACK-A5U
SKU RAPTRACKA5
#RAP-B-354U-TRA1
SKU. RAPB354TRA1
Old Jan 10, 2018 | 08:44 PM
Omega Man's Avatar
Omega Man
I literally just mounted one of these magnetic mounts a few days ago.
http://amzn.to/2qRb60X
I mounted it right above the the AC vent to the right of the steering wheel, below the line of sight so I don't block any of the road but high enough I can see it easily for turn by turn directions. Highly recommend it
Old Jan 10, 2018 | 08:55 PM
Omega Man's Avatar
Omega Man
It would let me post a picture in my prior post for some reason, but here ya go.
