4x4 issue
Old Jan 9, 2018 | 09:17 PM
kx125str99's Avatar
kx125str99
4x4 issue
hey guys my 4x4 last time I tried to use it didn’t help me haha. Wouldn’t engage in the 4low and when put in high with the ac is on vent switches to the defrost. Any ideas?
Old Jan 9, 2018 | 09:41 PM
CousinCarl's Avatar
CousinCarl
Common vacuum leak
Old Jan 10, 2018 | 06:43 AM
JGRNAUT_7.3L's Avatar
JGRNAUT_7.3L
If you still have the stock auto hubs definitely sounds like a vacuum leak. Easily fixed if you can track down where the leak is. You could also manually lock your hubs in if you needed 4x4 in mean time, just turn the dial to lock and make sure to unlock them when your done.
Old Jan 10, 2018 | 07:29 AM
Dan V's Avatar
Dan V
Check the vacuum lines to the hubs (from the frame) for leaks.
Old Jan 10, 2018 | 06:14 PM
kx125str99's Avatar
kx125str99
Ok will do. thanks
tstence
6.7L Power Stroke Diesel
Jun 27, 2017 01:44 PM
emeiers
Mar 11, 2013 09:02 PM
robs01f250
Aug 31, 2010 12:48 AM
sticks25
Dec 9, 2008 06:32 PM
BadDogPSD
Dec 9, 2006 01:32 PM
