2012 Transmission problems 6R80E
Old Jan 9, 2018 | 05:29 PM
CMOS's Avatar
CMOS
Howdy All,
My 2012 F150 3.5 EB has been great but recently, on an intermittent basis, after stopping at a stop sign or traffic light, it will not shift out of 1st gear.
The "fix" has been to either pop it in neutral and back into Drive, or sometimes I have to pop in Neutral, turn engine completely off, then restart and pop into drive.
Today it did this 4 or 5 times.
When it's working correctly, it shifts perfectly. I suspect some type of electrical connection issue - ?
Thoughts?
CMOS
Old Jan 9, 2018 | 06:23 PM
eriebasin's Avatar
eriebasin
Check out Fordtechmakeuloco on youtube. He points out some potential reasons to change the fluid early. Maybe this could shed some light on potential causes. He is also a member on this forum also. At the very least, this video is a good source for how the 6R80 works. He has many more videos on youtube. Good luck!
Old Jan 10, 2018 | 07:41 AM
CMOS's Avatar
CMOS
IIRC most dealers will use a Flush machine to service the fluid, but that doesn't touch the filter. Is there a filter in the 6R80E?
CMOS
Old Jan 10, 2018 | 12:44 PM
jdunk54nl's Avatar
jdunk54nl
Yes there is a filter...well technically a screen I believe.
I would suggest having the dealership flush the fluid and then have them drop the pan and replace the filter.
I just did this and it cost an extra $100 to have them drop the pan. The total was $300.
With either just the flush or just the pan drop it was going to cost $200 and that is well worth it to me not to have to deal with transmission fluid....it is the worst fluid in the vehicle to deal with and I will happily pay others to deal with it.
Old Jan 10, 2018 | 12:56 PM
CMOS's Avatar
CMOS
Been looking at YouTube vids. Pretty easy to drop the pan to change the fluid and filter (already ordered one on Amazon).
I'm going to do the service this weekend in hopes it clears up my issue.
CMOS
Old Jan 10, 2018 | 06:49 PM
WXboy's Avatar
WXboy
Erratic shifting on the 6R80 is almost always due to failure of the "molded lead frame" and there have been TSBs and recalls issued on it. You need to get yours replaced.
Old Jan 10, 2018 | 07:45 PM
CMOS's Avatar
CMOS
I'm leaning this way based on what I learned today. I'm hoping to do this myself as there are some really good YouTube vids for this.
CMOS
Old Jan 11, 2018 | 09:10 AM
CMOS's Avatar
CMOS
There's actually a warranty extension for this issue. I've read the document, which states that repairs are to be done for free, if the relevant codes are present in the PCM.
For some odd reason my truck is not throwing any codes. 2 days ago I experienced the symptoms (will not shift up to 2nd gear from 1st) about 5 times during the drive home from work, yet no codes when I checked yesterday.
Thoughts?
CMOS
Old Jan 12, 2018 | 04:50 PM
eriebasin's Avatar
eriebasin
Here's a video of the service.
Old Jan 13, 2018 | 06:52 AM
NASSTY's Avatar
NASSTY
X2
When my 2014 had lead frame issues it would drop from 4th gear to 1st gear locking up the rear wheels. I'd have to put it in neutral and pull over, put it in park, shut the truck off, pull the key out and restart.
If I didn't go through all of those steps it wouldn't shift out of 1st gear.
Old Jan 13, 2018 | 07:31 AM
Skip1970's Avatar
Skip1970
guess you have never changed gear oil.
Old Jan 13, 2018 | 07:34 AM
Tom's Avatar
Tom
Just out of curiosity, how many miles are on the truck?
I think the lead frame is your most likely culprit. The only way your transmission filter is clogged is if your transmission is already in the process of failing.
Old Jan 14, 2018 | 11:09 AM
P.Bronner's Avatar
P.Bronner
Lead frame
Old Jan 16, 2018 | 08:12 AM
CMOS's Avatar
CMOS
Guys,
I replaced the Leadframe myself on Sunday, as well as a couple other low-dollar parts (filter, connector sleeve, internal connector, gasket).
So far all is working. Since my symptoms were intermittent, time will tell if the problem is "fixed". I romped on it pretty good on Sunday without a hitch.
It was not a difficult job to do. Took some time, but not rocket science.
Tom - I have 101K miles on the truck.
CMOS
Old Jan 16, 2018 | 04:16 PM
P.Bronner's Avatar
P.Bronner
Thanks. It's always nice to get a follow-up.
