Tow package help PLEASE!
Old Jan 8, 2018 | 09:16 PM
GalaxyGirl's Avatar
GalaxyGirl
Hello all,
Can someone here please help me understand the tow package prep. I am in the process of purchasing a used F450 and I can't figure out what exactly the "tow prep package means" and if I need to get a truck that has it factory installed. I am going to be hauling a fifth wheel. Is this something that can be added after the fact or do I need it to have come factory installed?
GG
Old Jan 8, 2018 | 10:32 PM
First Dually's Avatar
First Dually
The Ford prep consists of 4 pucks (that allow mounting a compatible 5th wheel hitch) and another hole in the center (to allow inserting a goose neck ball). It is a great set-up and can be installed after the truck is built. OEM is Reese.
Old Jan 8, 2018 | 10:35 PM
GalaxyGirl's Avatar
GalaxyGirl
Thank you for responding! If I have it added afterwards, will it be the same? Is there any disadvantage to adding after?
Old Jan 8, 2018 | 10:47 PM
First Dually
It will be identical to factory installed if added after.
Only advantage of factory installed is less costly and installation hassle. BTW, a competent shop experienced in trailer hitches can easily handle the install.
Old Jan 8, 2018 | 10:54 PM
GalaxyGirl's Avatar
GalaxyGirl
Ok got it. I was confused because I had a read an article that was saying something about a tow packages having larger brakes and radiator cooling lines and all this other extra stuff, that confused me. Thanks for clarifying!
Old Jan 9, 2018 | 12:19 AM
mrgrayaz's Avatar
mrgrayaz
This is absolutely true in SUVs and 1/2 tons. The tow package will usually throw a lower gear set and another tranny cooler in or something.
Not do much on a Super duty.
I added the pucks afterwards - about $600 for parts from the dealer and $500 for the install. Order it from the factory and it's cheaper.
Old Jan 9, 2018 | 06:31 AM
djousma's Avatar
djousma
Ok, call me dumb, but on my F350 the "pucks", plate and in-bed plug was labelled "Fifth-wheel prep". However, for the life of me, I dont know what else it could mean, as every F450 is setup for towing.
It might help if you could provide the year or the F450 you are looking at.
Old Jan 10, 2018 | 05:41 PM
senix's Avatar
senix
The other part of a tow package will consist of a in the bed plug for the trailer, a must have and can be added after the fact as well.
Tow mirrors are a must and the trailer brake controller.
My self, unless it was a real good deal I would just rule out any truck that does not have these items to start with.
JohnnyGaloshes
Sep 18, 2017 08:33 PM
RomeSC
All Things Towing
Jul 27, 2016 02:05 PM
DetailerDave
Mar 21, 2016 06:58 AM
tseekins
2009 - 2014 F150
21
Sep 18, 2013 05:11 AM
beeser
Dec 21, 2008 10:02 PM
