86 250
Old Jan 8, 2018 | 07:10 PM
Gibsco's Avatar
Gibsco
Hey guys, new on here and to the ford world, have an 86 f250 with a 460 I bought for dirt cheap and I think I'm finding out why. The guy put a 600 c.f. carb on it, it idles great revs good in park but driving down the road if you get into the secondaries it spits and sputtered and wants to die, I have 6 to 7 psi at the carb with fuel and there is no cat on it so I'm kinda at a loss
Old Jan 8, 2018 | 08:41 PM
Brnfree's Avatar
Brnfree
What kind of carb?
If it’s an old Holley your secondary float bowl and passages may be full of varnish... if nobody ever got into the secondaries the gas just sat in the float bowl until it turned to varnish. Especially gas cut with ethanol.
Old Jan 8, 2018 | 10:12 PM
cadunkle's Avatar
cadunkle
Check the fuel level in secondary bowl, set float height. Failing that, rebuild it.
Also check that your timing is advancing properly. Could be seized advance mechanism not advancing.
Old Jan 8, 2018 | 11:34 PM
sdiesel's Avatar
sdiesel
probably incompatible with timing
Old Jan 9, 2018 | 12:09 AM
Gibsco's Avatar
Gibsco
Carb is a brand new edelbrock, I'll check the timing advance tomorrow and let you know
Old Jan 9, 2018 | 05:59 AM
Franklin2's Avatar
Franklin2
Originally Posted by Brnfree
What kind of carb?
Just to let you know, holley's have small ports at the bottom of the throttle body in the rear to prevent this. These small ports in the rear contribute a very small amount of fuel at idle to to prevent the fuel from getting stale in the rear of the carb.
Old Jan 9, 2018 | 11:56 AM
Gibsco's Avatar
Gibsco
Well the vacuum advance works just fine, I'm kinda at a loss.
Old Jan 9, 2018 | 12:03 PM
Gibsco's Avatar
Gibsco
Held the brake and put it in gear put the gas to the floor like I was trying to power brake, the truck would only get to about 1500 rpm but there was a bunch of black smoke coming out of the exhaust like it' running rich
Old Jan 9, 2018 | 12:41 PM
Lord Vokk's Avatar
Lord Vokk
Hmm, I had something similar, it was because the old choke on my 2150 was stuck open.
Sadly, mine was a bit hard to fully diagnose because I had a couple of overlapping issues.
I had some leaky vacuum lines, that allowed the very rich truck to 'sound' like it was idling good even though it was running rich even at idle. I guess you could say that it was leaking so much air from the leaks that the it was evening out the choke being open.
I know my 2150 is only a 2 barrel.....I'm just sharing because the net effect was similar.
-LV
Old Jan 9, 2018 | 02:46 PM
Franklin2's Avatar
Franklin2
Try lowering the float level in the carb. I have heard guys on here saying the edelbrocks were sensitive to fuel pressure. 6-7 psi may make the fuel level in the bowl too high.
If you wanted to experiment, if you have a rubber hose to the carb, take some vise grips and pinch it off after you let the truck run a little while and warm up. Right after you pinch the line, go in there quickly and power brake it again. See if it is any different. Of course it will eventually run out of fuel, but in the beginning see if it's not pouring black smoke anymore.
Old Jan 9, 2018 | 03:35 PM
Gibsco's Avatar
Gibsco
Okay, also looked at the choke to make sure it was open, closed it and it killed the motor, so seems like it' getting to much fuel and not enough air, so sounds like it could be a float issue, I have a line on a 750 holla, I might go that route. Thoughts?
Old Jan 9, 2018 | 06:08 PM
Franklin2's Avatar
Franklin2
Old carbs sitting around are nothing but trouble. All the gaskets dry out and the old ethanol fuel evaporates and gums everything up. I would commit myself to one of those carbs and then rebuild it before I installed it.
You can stick it on there and roll the dice. I don't have much luck with that though.
Old Jan 9, 2018 | 06:11 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
According to Edelbrock, The fuel pressure should not exceed 6.5 psi. You might want to get a regulator to drop pressure some.
Old Jan 10, 2018 | 09:52 AM
cadunkle's Avatar
cadunkle
Vacuum advance is not very relevant in this case, you could plug it and it should still run fine. Verify base timing is ok (10* is good) and that mechanical advance is working.
Old Jan 10, 2018 | 09:53 AM
cadunkle's Avatar
cadunkle
This still applies, check and set your float height in both bowls.
76BigBlock
30
Sep 14, 2011 01:35 PM
69 truck
Jun 23, 2008 04:51 PM
ceanz
Oct 12, 2006 09:10 PM
68 250 Flareside
Mar 27, 2006 11:44 PM
polywog77
Oct 3, 2002 11:24 AM
