Tailgate not opening
Old Jan 7, 2018 | 03:48 PM
Pioneer1's Avatar
Pioneer1
Have a new 2017 truckand when the fob or just using button, the tailgate does not lower. It releases but does not lower unless given some encouragement. Thought it might Because of cold weather but don't think that is the cause. Think I've seen some other guys with this issue. What have others found out?
Old Jan 7, 2018 | 05:32 PM
DRKBC's Avatar
DRKBC
If you have a bed liner, it’s catching on it and you need to shave a little off the sides of the rubber bumpers.
Old Jan 7, 2018 | 05:35 PM
Pioneer1's Avatar
Pioneer1
Just spray in liner. It's catching somewhere on left side of latch. I put some wd40 etc. And no luck
Old Jan 7, 2018 | 05:47 PM
DRKBC's Avatar
DRKBC
Mine is spray in as well. The Ford dealer will do it for you, you actually need to shave a little off those bumpers with an razor.
Old Jan 7, 2018 | 05:49 PM
Pioneer1's Avatar
Pioneer1
Where do you shave it off? I'll look more closely tomorrow. Thanks
Old Jan 7, 2018 | 05:50 PM
DRKBC's Avatar
DRKBC
This idea. Just so it can release the tailgate.
Old Jan 7, 2018 | 05:57 PM
grege's Avatar
grege
Mine is sticking some too after getting my Line-X last week. Thanks for posting this.
Do you shave both sides of that rubber piece? I think it looks like it but thought I would ask to make sure.
Old Jan 7, 2018 | 06:01 PM
DRKBC's Avatar
DRKBC
No just the sides so they still have the spring to push out the tailgate. Both bumpers but just the sides. On mine at least.
Old Jan 7, 2018 | 06:11 PM
DRKBC's Avatar
DRKBC
Sorry, looks like a little off the bottom as well but maybe try just the sides first then the bottom if it needs it.
Old Jan 7, 2018 | 06:19 PM
grege's Avatar
grege
Sounds like a plan. Thanks.
Old Jan 8, 2018 | 12:02 PM
casemiro5's Avatar
casemiro5
This happened to me. Had to take to dealership to replace actuator in the tailgate. Covered under warranty.
finnf250
Feb 22, 2017 07:20 AM
jdenny21
6.7L Power Stroke Diesel
Aug 28, 2012 11:04 PM
Smo key
1997 - 2003 F150
May 19, 2007 05:31 PM
jba
2004 - 2008 F150
Oct 11, 2005 09:22 PM
oneofakind97
Offroad & 4x4
Oct 4, 2005 02:51 PM
