Removing turbo- wits end
#46
So when I removed the valve cover today to replace the valve cover gasket and UVCH harnesses, I found this. So I guess this was my actual problem not the harness or turbo. Granted, my turbo blew the seals so it needed to be done but I was frightened at first when I popped that valve cover off and saw a rocker arm loosey goosey.
#49
When it happened I had downshifted into 4th going up a slight hill and it just started smoking and running a little rough. Buzz test showed 3 out of 4 injectors failed on the passenger side where the bent rod came from so I assumed blown turbo seals because of the oil, and then running rough because of the UVCH harness. I am doing all of that anyways so that's good that I will have at least all that stuff replaced. But some guy I know who knows these trucks said that it's more common than you'd think on these trucks and just throw a new one in and you're good to go.so I will double check all the rest and for now, just throw one new one in and maybe start planning on upgrades in the near future. E fuel is first. But I just went under contract tonight on my first house purchase so I'm basically just trying to get it back on the road anx running for the next month.
#50
#52
Yeah, I'm running stage 1's with DP tunes, and so it's probably only a matter of time before it happens again. So I'm going to throw a new one on for now, but probably start looking for some good aftermarket ones this year.
#53
Also, does anybody have an idea on what I can do to take the EBPV out of the pedestal and plug it? In assuming on the one end I can just put that brass colored plug back in with the snap ring, but what do I put in that small hole where the stem sticks out?is there a small freeze plug I can put in there, or can I just shove a bolt in it with some locktite, and maybe have somebody weld it?
#54
I’ve heard you can drill and tape the oil feed for it and plug it with a pipe plug 1/8” i believe so same size if you already drilled in an egr probe. I’d do that over a freeze plug. I haven’t had one apart to see which end but i know that’s whats you do. It’s aluminum so it should be easy to tap.
#55
#56
#57
