Freaking power mirrors :(
Old Jan 6, 2018 | 07:11 PM
Glowplugger's Avatar
Glowplugger
I'm working on my power mirrors and they still don't budge. New switch, fuse is good. Got power to the fuse, not sure how to check to see if there's power to the switch. With the meter on it I can touch every connection and it's all dead. Not sure where to go from here. All the wiring looks good all the way to the door grommet.
Anyone have experience with this?
Old Jan 6, 2018 | 08:48 PM
jimjokjv's Avatar
jimjokjv
Power to the switch only when ignition key is on or in accessory?
Volt/Ohm meter or 12v test light at the switch. If not I would suspect a break in the wire from the fuse box to the switch and an ohm meter would verify that.
Old Jan 6, 2018 | 09:26 PM
Stebs's Avatar
Stebs
On my 02 excursion, the orange with light green stripe at the switch is the power in, and is hot at all times...
Old Jan 6, 2018 | 09:28 PM
Colorado350's Avatar
Colorado350
Are you SURE that the motors IN the mirrors are good?
Old Jan 7, 2018 | 09:08 AM
DieselDenny's Avatar
DieselDenny
Both mirrors doing the same thing??
Like nothing?
Old Jan 7, 2018 | 09:23 AM
Glowplugger
Haha! Yes, I thought of that after the first round of tests. Good thinkin! Key was in the ON position and still no power.
Thanks! I'll triple check it again today, but sticking a meter in any and going to all others had no power.
No, this is a new truck. PO said they worked until he got them wet with a swipe of rain from the wipers, which probably means they've never worked since it was built.
Like nothing?
Exactly that. Nothing at all from both mirrors. They're tow mirrors that flip inward. I assume they aren't supposed to work when folded inward, right? To be sure, I had them folded out when testing.
Thanks for the responses guys. You can't beat this forum for a helping hand when the frustration builds to impossible levels.
Old Jan 7, 2018 | 09:46 AM
guitarpicr's Avatar
guitarpicr
If neither one does anything (makes any noise) it is most likely- fuse, broken wire, bad connection at driver side switch. They should work out or in. I'll go check mine to make sure for u.
Old Jan 7, 2018 | 09:50 AM
guitarpicr's Avatar
guitarpicr
Yes - They work folded in or out.
Old Jan 7, 2018 | 09:53 AM
guitarpicr's Avatar
guitarpicr
Dumb thought - Did you verify that the po didnt change mirrors out & maybe they are manual only? Have you removed door panel yet & eyeballed them ?
Old Jan 7, 2018 | 11:17 AM
Stebs's Avatar
Stebs
i went through the same thing, in my case was a bad switch... you need to put your meter or test light ground on a good frame ground to verify power at the switch. I just found a good bolt nearby to use, and not one on the door itself...
Old Jan 7, 2018 | 05:18 PM
AllaboutMPG's Avatar
AllaboutMPG
Wiring diagram
Maybe this will help
MikeRizz
6.4L Power Stroke Diesel
Apr 19, 2021 02:18 PM
Kevinpmac
Apr 10, 2008 09:02 PM
Immortal_mario66
Apr 27, 2007 10:53 AM
billbain
Apr 29, 2005 10:08 AM
Switch
1997 - 2003 F150
Nov 9, 2004 12:23 AM
