Looks the right length for the AIH. I would tape it up if your not planning on using it. May cause a fire when powered up and touching stuff it shouldn’t be.
Are you sure that it goes to ground and checked with a VOM and not getting "lost" in the wire loom? The AIH draws a fair bit of current as would be indicated by the wire size. The AIH is grounded through the AIH element to the spider body.
TRUE.
And being that it is a circuit, the return path needs to be as big as the supply path. And, it is actually a hotly contested subject which direction current "flows". But that is another topic.
FALSE.
The OP's cable in question is the ground wire for the AIH. There is a ceramic insulator that separates the positive and negative cables on the AIH stud.
Both the power and ground connect to the element and are separated by ceramic insulators. Most just leave the ground in the valley because its easy.
I removed it on mine, plenty of stuff in that valley didn't need any extras.
see picture in link link
