7.3 PS Powertrain
Old Jan 5, 2018 | 07:02 PM
carlwell's Avatar
carlwell
7.3 PS Powertrain
I am resto-moding a scout ll with a 7.3 power stroke and need to know exactly what transfer case I need. I will have a ZF S6-650 tranny. Also, any tips since this is my first time doing anything like this.
Old Jan 5, 2018 | 09:27 PM
farmert's Avatar
farmert
You will need a transfer case that was used behind the ZF6 from a Superduty, as the output shaft is larger than the output shaft on the ZF5s or the old T18s. I believe the Superdutys used a NP 281, but I'm not 100% sure on that.
Old Jan 5, 2018 | 09:48 PM
97-psd's Avatar
97-psd
You picked a doozy of a swap. The 7.3 is a heavy motor to drop in a scout. Aren’t they passenger drop axles? A transfer case may be tough to find. I think most of the ones that bolt up to that tranny will be driver drop.
Make sure you have a good donor truck as you will need all of the electronics out of it, including the dash.
Are you dead set on the 7.3? There are other diesels which would be easier to swap in. If you decide to do it make sure you post your progress. We love good builds!
Old Jan 6, 2018 | 03:06 PM
z31freakify's Avatar
z31freakify
4BT Cummins would suit the Scout better, more so if its mechanical injection.
Old Jan 6, 2018 | 04:43 PM
Hit Man X's Avatar
Hit Man X
The IH SV series engines are pretty heavy, 345" is about 700lbs. They are industrial/medium duty engines. Not light duty stuff from the big three of that era. Check out the skirt length and size of pistons/rods. Power is flat and will run all day at 3000rpm...Just not a ton of horsepower as the heads are poor.
I have worked on a '76 SII for years. Not an expert by any means, just normal stuff.
Ours has D44s factory. Dana 20 case. Auto hubs. 345 V8. 727 trans. Neat vehicle! Down because of carb issues. :/
I would love to see a build thread if you have one!
carlwell
Jan 5, 2018 07:29 PM
that-1redneck
Jan 25, 2012 09:17 AM
powerstroke F350
Jun 7, 2011 06:01 PM
Kelson89
Jan 20, 2010 05:14 PM
muscletruck7379
Jun 30, 2004 12:15 AM
