Sponsored by: Auxito
Dome lights and windows won’t work.
Old Jan 5, 2018 | 05:03 PM
Dillan Clark's Avatar
Dillan Clark
​​​​​​I have an 01 f150.. the other day I was driving down the road, all the windows worked fine. I turned my dome lights on for something and one started to flicker (it has done this before) so I jiggled it around a little bit because that usually works then both stopped working. After that the all the windows stopped working. The lock switch on the panel works but nothings else. So now I’m without dome lights and windows but I can lock all the doors from the switch and the key FOB. I’m not sure how the dome lights would affect the windows but they seemed to all stop working at the same time. (All the plugs on the panel switches are hooked up)
Old Jan 6, 2018 | 09:17 AM
alloro's Avatar
alloro
The relay coils for the interior lights relay and the accessory delay relay are both powered from the battery saver relay. So I'd start with fuse 105 in the battery box, then fuse 14 under the dash, then finally the battery saver relay itself in the under dash fuse box.
nut4brend
Feb 18, 2015 09:44 AM
SVTDarin
Jan 30, 2015 04:46 PM
mike2112
2004 - 2008 F150
Aug 29, 2012 05:54 PM
texans
Jul 23, 2011 12:08 PM
SnubNose
Electrical Systems/Wiring
Aug 7, 2003 08:46 AM
