Sponsored by: Real Truck
Rocker switch panel
Old Jan 3, 2018 | 01:59 PM
StrokinIT2001's Avatar
StrokinIT2001
Rocker switch panel
Want to put one of these int my truck but can’t find a place it would fit I know I’ll have to do some cutting. Looking at these two areas to put it.. anyone have other ideas. I know I would have to take my 4x4 switch out but I have my 4x4 hooked up somewhere else so the switch is just there...
Old Jan 3, 2018 | 02:11 PM
D.Yaros's Avatar
D.Yaros
They won't fit in the Copenhagen spot?
Looks like the best bet is the slot on the lower left.
Might also investigate removing the cup holder and using that space?
Old Jan 3, 2018 | 02:24 PM
StrokinIT2001
Hell no not the cope slot... looking at the measurements is another issue. I have to form the mount to the contours of the dash.. if I used that lower left are these dash parts hard to find Incase I removed the switches later??if I remove the cup holder (which I use often) I would have to ask fte for cup holder placement suggestions😆
One issue after another a vicious circle
Old Jan 3, 2018 | 03:25 PM
Pocketlint's Avatar
Pocketlint
You could always go with a configuration something like this
Old Jan 3, 2018 | 07:42 PM
StrokinIT2001
That’s pretty nuts... I think I can trim the switch plate down and put it where the 4x4 switch is and still look pretty clean... just don’t want it to look like a hack job..I’ll post it afterwards
sammie0126
Dec 18, 2020 02:36 AM
RMBC Freeride
Dec 30, 2017 03:38 PM
k9education
Aftermarket Products
Jul 21, 2016 12:11 PM
SuperDuty93
Jul 6, 2012 07:22 PM
1975StroppeBaja
Mar 21, 2010 04:21 PM
