What oil are you using now with the Ford approved list
I need to change my oil soon and not sure what to use, I have been use Delo 15-40 for years, but is not on the list. Have been thinking about using a synthetic, but is T6 with the new rating on the list? Just wanted to know what you are all using, thanks.
I use Mobil delvac 5-40 full synthetic. have some cj4 and ck4. When someone says it is a problem for the 7.3 engines that has done testing in them and had something to do with making them ill worry about it. I buy it on sale and send in the rebates ends up about 35 dollars for 5 gallons with tax.
Delo is fine. Don't waste your money on synthetic oil unless you live somewhere that gets super cold then synthetic could be helpful during the winter months.
I believe the CK-4 stuff is fine to run in the 7.3. Fords statement was about the 6.7 Powerstroke. Rotella t4, Delo, Delvac, Valvoline, Motorcraft, or any other 15w40 diesel oil is fine to run. I have been running Motorcraft but I picked up about 9 gallons of Castrol 15W40 at Walmart on sale for $5 a gallon a few months ago, I also have a few gallons of Delo.
A.) I don't recall ever seeing a Castrol DIESEL RATED oil at Walmart.
B.) I have never seen any DIESEL RATED oil sell for $5/gallon.
C.) $1.25 /qt is a plausible sale price for regular NOT DIESEL RATED, conventional automotive 15w40 Castrol.
See the theme/pattern here? I highly doubt that Castrol oil is for diesels, in which case you definitely should not put it in your 7.3L
I used to use Rotella T6, but the engine always seemed to run weird after the first couple thousand miles.
I have since switched to this Lucas High TBN ( anti-wear additives) CI-4 oil
https://lucasoil.com/products/lucas-...h-tbn-ci-4-oil
Along with switching to a larger FleetGuard venturi oil filter ( which has a built in bypass filter section), I will be aiming for 10k mile oil changes.
