Looking to cut my frame down from 118" wheelbase to 110 to accommodate the bed I have. Where is the best place to take the 8" out? I plan on cutting in a "Z", not just a straight cut. I've found some good articles and videos on shortening frames in general, but not on the 56. I've searched and read a lot of the posts here too, but nothing is really said about where to take the 8". Just looking for some advice before I hack! Thanks!
I'd move the rear end closer to the cab and cut the bedrails short.
But on my truck I'm chopping it right behind the cab, only because my F4 was lengthened at some point at the same spot. Rather chop out their suspect work and have it done right.
I think easiest place is behind the cab ... nice long stretch with nothing in the way... of course you know you'll have to shorten driveshaft and the fluid lines will have to be redone... ebrake cable also... but those are just things...
In addition to the "Z" cut I'd also recommend adding some plate on each side of frame rail to stiffen the cut/weld... at least 5 or 6 " past the end of the cuts. Google 'fish plates' or 'shortening frames" to see examples
Since these trucks have a two-piece driveshaft with a support bearing in the approximate midpoint, will the geometry be affected? Is there a point in which a carrier support is rendered ineffective if shifted towards either end?
I would cut the frame in the straight part just under the back of the cab. Cut it at a long angle, 20-30 degrees, instead of a "Z", it would be a lot easier to fit and line up. If welded properly, a fish plate wouldn't be necessary. You can fish plate it on the inside only, so it won't show, with a diamond shaped fish plate.
Mark
Are your measurements correct? If you have an F2 or F3 the wheelbase would be 122". The F1 is 114". I ask because a PO cut my 1950 F2 down from 122" to 110". Then someone torched off the rear of the frame and installed a 1952 F1 short box. This caused the rear wheels to be in an odd location. (see picture). I had to move the fenders forward 4".
The rear wheels are too far forward.
I moved the fenders forward 4" to compensate for the odd frame dimension.
The frame was cut right behind the cab then fish-plated. Good welds but I think an offset or Z cut would have been the right way to do it. . . . but I didn't have a vote.
I replaced the rear part of the frame rails and installed a rear crossmember. I them mounted a gas tank in the rear so that I could get the tank out of the cab.
I shortened mine back in the dark ages(pre-internet). I did a straight cut and a square fish plate. We cut it right behind the 3rd running board mount, and took out 8". If your using a short box box and running boards(i.e. not shortening your long box stuff) the 3rd running board mount will have to go, and will give you a little more room to play with for a diagonal cut. You also need to take about 10" off the back. It would help to have pics(or a short box frame to reference) I didn't and it has bitten me in the @ss a couple of times now.
Great tips. Thank you everyone! I didn't think about the 3rd running board mount, but i'm sure that will have to come off for the "z." I've been knee deep in rust repair and just need to step away and have plenty of work to do on the chassis. I'll come back and let you guys now how it turns out with the frame.
I originally cut just behind running board mount I didn’t like it so I cut just behind cab and built a tube rear end. Air ride and jag irs swap while I was at it. Still need to add another 36” once I get the fuel cell.
You can see I had to reattach the 3rd running board. Wasn’t a big deal. 24 1/8 on center, I used a straight edge to keep it level.
