2016 Starter cleaning question
Old Jan 2, 2018 | 10:15 AM
cangim's Avatar
cangim
Last summer I had two times where the gear didn't slide out to grab the flywheel, happens wasn't too worried about then. Bring forward to the last couple of months, it was pointed out when my truck starts it has a zing sound to it. Basically sounds like the gear is now sticking so it will not retract as fast and gets over spun. Looking at a few different diagrams this morning I am curious if I can clean/lub the end splines/gear. Anyone pull a starter apart or just replace?
Old Jan 2, 2018 | 11:44 AM
F250_Super_4X4's Avatar
F250_Super_4X4
I have removed and replaced plenty of these starters but have not rebuilt one. Removing the starter can be a royal PITA if you have never done it before.
All you should have to do is remove the casing bolts and remove the gear housing. Some starters the housing is also pressed on. Clean and reassemble. It would have to be seriously gummed up for this to be the problem. I recommend replacing it.
Old Jan 2, 2018 | 04:59 PM
Just Strokin's Avatar
Just Strokin
If you are under the 3yr/36,000mile warranty, let Ford do it. It might be to the point of needing a flywheel.
agaristo77
1978 - 1996 Big Bronco
Apr 6, 2012 01:50 PM
1951flatheaddave
Mar 16, 2012 09:39 AM
Snowking
Flathead V8 & Flathead 6
May 2, 2007 09:41 AM
ddrumman2004
1997 - 2003 F150
Jan 24, 2005 12:26 PM
fast77
Bronco II
Jan 18, 2002 06:57 PM
