GCWR?
Old Jan 1, 2018 | 04:29 PM
orion1968's Avatar
orion1968
GCWR?
The towing guide show 3 different numbers for 5th wheel. It says to look in owners manual to determine yours. My manual show 23500 for F250 diesel. On the chart it does not have that number. I know 1 of the 3 is with tow package that I don't have so it leaves 22500 or 23100. So what one is correct?
Old Jan 1, 2018 | 04:35 PM
wb6anp's Avatar
wb6anp
will this help?
http://webcontent.goodsam.com/traile...wGuide2017.pdf
Old Jan 1, 2018 | 05:44 PM
2009kr's Avatar
2009kr
You'll be over your GVWR well before you hit those towing numbers on a F250.
Old Jan 1, 2018 | 06:01 PM
orion1968's Avatar
orion1968
Originally Posted by wb6anp
That shows a lower tow rating with the tow package than without.
Old Jan 1, 2018 | 06:12 PM
OEM's Avatar
OEM
F-250 is max 10,000lbs GVWR.
EDIT; you’re looking for combined. Ignore me, I’m dumb.
Old Jan 1, 2018 | 06:16 PM
HRTKD's Avatar
HRTKD
This is the Ford guide: https://www.fleet.ford.com/truckbbas...wing_Guide.pdf
See Page 21 for conventional (bumper pull), page 22 for 5th wheel.
As an example, my conventional trailer capacity is 18k and the GCWR is 28,700. I have the 4x4, 176" wheelbase, 3.55 axle, diesel F-350 with 18" tires. Yours will depend on wheelbase, bed size and cab size, axle ratio and engine.
Old Jan 1, 2018 | 06:26 PM
wrvond's Avatar
wrvond
The way I'm reading it is your GCWR = 22,500 lbs. with a maximum loaded trailer weight of 14,700 lbs. This represents the highest possible weight of a loaded trailer the vehicle can tow, based on a minimum towing vehicle GVW. It assumes a vehicle with any mandatory options, no cargo, a pin weight of 15% and a 150 pound driver only. Additional options, passengers, cargo, and the hitch must be deducted from this amount.
HOWEVER!
Look on the safety compliance certification labels located on the driver door pillar. You'll see front and rear GAWR and GVWR values that cannot be exceeded. And finally, take a look at the cargo capacity label on the door pillar. The total weight of options, passengers, cargo, hitch, and pin weight cannot exceed this amount.
If your truck has a cargo capacity of 2000 lbs., subtract hitch weight (say 250 lbs.), passengers (200 lbs.), cargo (500 lbs.), that means you have enough cargo capacity (in this example with made up numbers) for a pin weight of 1000 lbs. So with a pin weight limited to 1000 lbs. maximum, you are limited to a fully loaded trailer weighing 15,000 lbs.
So, while the GAWR and GVWR are important numbers that should not be exceeded, you are going to run out of cargo carrying capacity long before you hit the limits on those numbers.
Old Jan 1, 2018 | 08:13 PM
orion1968's Avatar
orion1968
I am not asking for the cargo weight. There are 2 numbers that are listed as GCWR under my CCSWB 4X4 Deisel. My concern is that number and my RAWR of 6340. There is a 600lb difference from 22500 and 23100 in the Ford towing guide.
FWIW I have had my truck weighed and I have ~1650 cargo capacity with 2 passengers 3/4 tank of fuel. I will using an Andersen hitch.
Old Jan 1, 2018 | 08:32 PM
HRTKD's Avatar
HRTKD
The difference is if you have the tow package or not.
Old Jan 1, 2018 | 09:40 PM
wrvond's Avatar
wrvond
And based on the information you supplied, I answered your question as thoroughly and as accurately as I could.
Old Jan 1, 2018 | 11:21 PM
SloScooter's Avatar
SloScooter
HOWEVER!
With those calculations you couldn’t even pull much of a 5th wheel toy hauler as most have a pin weight of 2k-3k lbs. so a F250 seems worthless in the 5th wheel toy hauler world. Maybe I am missing something in the calculations. I am assuming that most of, if not all 2500’s are overloaded on the road then?
Old Jan 1, 2018 | 11:55 PM
blolmaugh's Avatar
blolmaugh
I had a 17 F-350 SRW, and i was about maxed without the wife and kid, or packed to go camping. I now have a drw.
Old Jan 2, 2018 | 12:41 AM
SloScooter's Avatar
SloScooter
By the numbers it looks like dually is the only legal option.
Old Jan 2, 2018 | 01:04 AM
USSenator's Avatar
USSenator
Exactly. A F250 is worthless, except to avoid registration taxes. A F350 is basically the same price.
Old Jan 2, 2018 | 01:12 AM
wb6anp's Avatar
wb6anp
Not worthless It is fine if you only tow light like I do, 6000lb tt and dont need anything bigger. It is worthless for a 5er though imo. especially after seeing the one that wrecked towing a TH 5er.
