New LED headlights problems
Old Jan 1, 2018 | 04:11 PM
gaforddriver's Avatar
gaforddriver
5th Gear
My son got me 2 new 9007 (HB5) LED headlight bulbs, and 2 9007 (HB16) inline resistor kits for my 2000 Expedition for Christmas, and for the life of us, we can't figure out why they keep cutting off and back on all by themselves. Hoping someone here can steer us in the right direction. So far, this is what's happening.
With new 9007 (HB5) LED bulbs installed directly to the factory wiring, they blink fast after about a minute or so, and never stop blinking.
With the inline HB16 resistor kits installed, and mounted to metal as per instructions, they will work for about 10 to 15 minutes and then shut off for a second or two, and then come back on for a minute or so and go back off for a second or two....and then repeat that scenario over and over.
Going to make an attempt to post pictures of the kits and bulbs in case that helps.
Old Jan 2, 2018 | 09:12 AM
alloro's Avatar
alloro
Those are the wrong ones for a 2000 Expedition. In 2000 the headlight wiring is not monitored so the resistors are unnecessary. These are the ones I installed in my 2001 Navigator and they never game me a problem.
https://www.ebay.com/itm/2pcs-9007-H...19.m1438.l2649
Old Jan 4, 2018 | 02:36 PM
gaforddriver
5th Gear
I followed your link, input my expeditions info, and it said those were not compatible with mine. I then input your vehicle info and it also said yours wasn't compatible. Did they plug right up to the factory wiring on yours?
Old Jan 4, 2018 | 11:46 PM
Skauber's Avatar
Skauber
For LED lights, the best ones out there in terms of retaining the correct beam shape and all that is Philips Lumiled right now, though be careful as there are counterfeit ones for sale as well. I use Lumiled in my '05 Expy and I have the blinking issue as well. It doesn't blink "forever" though, it stops when all the modules go to sleep after about an hour. The VSM also sets a code for broken headlights. It doesn't really bother me though, so I haven't gone through the trouble with any resistors or anything like that.
Old Jan 5, 2018 | 07:38 AM
alloro's Avatar
alloro
You can't always trust the eBay compatibility charts. The listing says it's a 9007/HB5 lamp which is what both yours and mine use. You could always double check with the seller and ask the compatibility question.
Jerm800
Feb 20, 2022 12:36 PM
slickoneuk
Jan 18, 2013 04:43 PM
Crash8088
Aug 4, 2008 10:54 AM
melt
2004 - 2008 F150
Jun 17, 2005 10:21 AM
FreeAgentRider6
1978 - 1996 Big Bronco
Jul 19, 2003 01:07 AM
