2018 Annual B.S. Thread!
#526
That’s another I can’t make, gotta be in Houston the 17th, because of the new limitations on my right arm I’ll be retraining to do controls for 2 months. They’re gonna let the old gear head chase “TRONS”. My boss thinks it’s a great idea as I know the engines, generator, all the auxiliaries and support systems so I can make them play well together.
Guess I gotta brush up on the “Theory of Elephants”.
#529
I'm over at Rod Run in Long Beach the weekend of the 8th. I could do a pancake run the 22nd as things stand now, pending having a working Ford =P
Ex is all put together today, but Ranaway found the radiator leaking after everything went back together, so a new one from Performance Radiator will go in Monday and then I can have my rig back! There are one or two injectors we're going to keep an eye on, as they are a bit blacker than the others. I left it to Torin's judgement and if the time comes for injectors I'm sure I'll #SendIt and go bigger so I can stage 2 the turbo, cuz I'm an addict that puts aside logic regarding reliability/maintenance when it comes to having a KICK *** AWESOME TRUCK I CAN BRAG ABOUT - cuz, ya know.. badass trucks are awesome...
I also finally decided to part/scrap the V10, so we hauled it off to Turbo's house to have more room to rip stuff off for our green excursions before we sell/scrap the rest.
The green 6.0 work order is currently as follows - they started Monday and had everything back together Thursday, the radiator being the unforeseen exception.
ARP Stud Kit with all updates
-heads went to the machine shop, not sure if they got o-ring'd, I keep forgetting to ask
BPD Heavy Duty Remote Oil Cooler
BPD 7.3 fan clutch adapter kit
HPOP
ICP
Up Pipes
Exhaust manifold went to the machine shop - turns out previous owners tried to weld things together and so we're properly fixing their janky fix
Electronic Fuel PSI gauge plumed into the cab and I'll get a gauge myself
Oil pan, gasket, and hardware - turns out it was in pretty bad shape
Radiator
Serpentine belt
Delo Oil
ELC coolant
HPOP
ICP
Up Pipes
Radiator
Serpentine belt
Delo Oil
ELC coolant
#531
I know removing the body is part of the process, but that still gives me a pucker seeing it up on a lift like that. Hope we can check it out after pancakes!
Happy Friday everyone.
#533
The Ex has been parked with issues or in the shop for more than a month - you have no idea how stoked I am to be back in my big rig again. Especially with all that work done - I'm ready to throw the hammer down in that bad boy =)
I actually really just want to be able to tow over to my beach lot without paying 600+ for a rental Duramax...
#534
It’s taken two weeks to order parts for my elliptical and I’m going nuts. A month without my truck would put me over a cliff.
Going crabbing in a few minutes...I’ve heard to catch is good this year, so hopefully I can pay off my license.
#535
Well if it does not then you will be in a bad mood.
Then all the people around you will have all the crab they can deal with.
Just not the yummy kind.
Good luck on the crabbing trip.
#537
Even in crappy weather, it’s a good day when you get out in a boat.
#538
Well if everyone wants to know how hard my day sucked take a look at this link.
https://www.ford-trucks.com/forums/1552916-why-me.html
The up side is I was not hurt but can't say that for 2 of the other cars passengers.
Buckley, Wa had construction projects there that were contributing factors to the backup
I was stuck in.
I was stuck in.
