Front/Rear Differential Capacity?
Old Jan 2, 2018 | 11:59 AM
Walleye Hunter's Avatar
Walleye Hunter
OK, now I want to dig a little deeper...I have this parts truck with a Dana 60 in the front end (presumable an open rear). I have a deceased '92 E-250 with a Dana 60 LS 3.73 non full floating rear in it (semi-floating?) (If you have this much stuff you might be hillbilly). Can I install that older LS into that other housing? I suspect it's a smaller size ring gear.
Old Jan 2, 2018 | 12:06 PM
carguy3j's Avatar
carguy3j
A.) You really don't want to do that, even if you can. Assuming this is for street driven truck, keep the FRONT an open diff
B.) My guess would be no they won't interchange. But, call these guys and ask.
FORD - Torque King 4x4
Old Mar 1, 2024 | 01:56 AM
anyusernamenottaken's Avatar
anyusernamenottaken
4th Gear
Thank you- confirms what I found
Originally Posted by Colorado350
Nobody's asked if you're using the stock cover or an aftermarket cover? My D80 with an aftermarket cover took 4 quarts.
I’m changing mine this weekend and everything I see says exactly what you said, 4 -4.25 quarts. Appreciate you chiming in, now I can still trust the specs I have and I don’t have to start digging all over again.
Old Mar 1, 2024 | 05:37 PM
RA101725's Avatar
RA101725
Banned
Highly recommend one of those Lube Locker gaskets if you are reusing a stock style cover. If money is no object, those fancy new Banks covers come with a drain plug and sight glass for very easy future servicing.
Old Mar 3, 2024 | 12:51 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
A great bang-for-the-buck upgrade is an aluminum cover from 08 up models
8C3Z-4033-A 8C3Z-4033-A
gammatino
Sep 30, 2018 11:53 AM
fordyduty
Mar 1, 2010 02:49 AM
mybigredford
Mar 13, 2006 05:27 AM
BigShelby
Oct 20, 2003 08:09 PM
Miketnf150
1978 - 1996 Big Bronco
Oct 16, 2001 08:38 PM
