Sponsored by: Real Truck
rear diff oil
Old Mar 12, 2006 | 07:53 PM
mybigredford's Avatar
mybigredford
rear diff oil
it says to put 75-140 syn only in my rear diff, am i able to put a heavier oil in there or not?
Old Mar 12, 2006 | 08:00 PM
Fordbronco69's Avatar
Fordbronco69
Infidel
If its a limited slip diff you dont want to put anything in there other then 75-140 syn oil with some additive ford has for limited slip diff's.
Old Mar 12, 2006 | 10:03 PM
mybigredford
no, i dont have limited slip, just the regular one wheel slip, wish i had limited slip though.
Old Mar 12, 2006 | 10:10 PM
dsldrvr's Avatar
dsldrvr
Why would you want to use anything heavier than 75-140???
Ar you thinking the Redline Xw-250 or something? If you go that route I would think only use if you into some special , non-normal use, like truck pulling or Monster truck building and know what you are doing.
Old Mar 12, 2006 | 10:18 PM
Fordbronco69
Infidel
If you dont have a limited slip diff then i dont see why putting in a heavier oil will hurt things. Note: that syn oils help in cold climates and you dont have to change the oil as often as dyno oil.
Ive got a limited slip diff in my truck but when i got stuck and noticed that it wasnt working i decided to take a look. When i poped the cover off, i could see clutch material in the oil so when i went to put oil back in it i noticed that little tag for the oil. But since the clutchs were already gone i decided to put 90w in there untill i either get a locker or buy a new clutch pack from ford. That was about a month ago and i still havnt got around to doing it, havnt noticed any differences.
Old Mar 12, 2006 | 10:51 PM
mybigredford
i was just curious, noticed thats what the tag said on the diff and thought i would ask
Old Mar 13, 2006 | 05:27 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Thread moved to Super Duty forum
