Out with E4OD
Old Dec 31, 2017 | 02:01 PM
sanco's Avatar
sanco
Out with E4OD
Hi All, new memeber however I'm not new to wrenching and fabrication
Back in 2008 I installed an FSO-6406A Eaton-Fuller 6 speed OD into my 2001 Dodge 3500 and also fab'd a transfer case adapter to marry the Fuller trans with the transfer case. Transmission has had 00000000 issues since installed.
Now for my next project. I have a 1994 Ford 450, 7.5 460 engine and a dead E4OD transmission. It also has a butchered frame behind the rear axle. It's also not the correct frame for a flat bed. Game plan is to section the frame and install a good frame section made for a flat bed. Next I would like a 13 or14" clutch and install an FSO-8406A transmission that was bought on EB for $149.00 new and unused.
Mark, I've read many of your posts and you seem to be the "go to" guy when some needs Help or info. I just need info.
From my understanding, the 370, 460, 429 and 514 were installed in Ford Medium Duty trucks along with the smaller 4 and 5 speed Fuller transmissions. I have seen a few pics of the housing that fits the Ford block and has the trans mount for an SAE #2 or SAE #3. The next big issue is finding a flat flywheel that will mount to the 460 crank and take a 13 or 14" clutch.
Most time I haul heavy for short distances so I am not concerned with the weight of the trans/clutch as I am about durabiliyty and service.
Can anyone provide a lead for the flywheel housing and flywheel??
sanco
Engine Swaps
Nov 20, 2018 01:37 AM
sanco
Engine Swaps
Jul 26, 2018 09:53 AM
crazed87bronco
52
Mar 29, 2011 02:53 PM
F350_Hauler
Dec 15, 2006 09:43 PM
QUEBEN
Jul 12, 2004 10:44 AM
