1994 4R70W problems
Old Dec 30, 2017 | 08:18 AM
AZmoparguru's Avatar
AZmoparguru
1994 4R70W problems
Hey everybody, I’m having an issue with the 4R70W in my 94 F150. The issue is, when the trans is at operating temperature, I’m getting a bad shudder during the 1-2 shift, similar to a converter shudder. The trans itself was rebuilt by Ford and only has about 30,000 miles on it. No issues with any other gear, there are no codes, and no issues with converter lockup. There is no material in the pan, always filled with Mercon V. I even installed a new bonded 1-2 accumulator, and swapped the shift solenoids and lockup solenoid and the result was no change. It will not act up at all when it’s cold. I’m about ready to pull it out and go through it and rebuild it, but was wondering if there was anything else I can check. I though about the EPC solenoid, but again, there are no codes. I’d appreciate ANY suggestions
Old Dec 31, 2017 | 11:41 PM
jk080's Avatar
jk080
Transmission Rebuilder
You may want to install a shift kit before you pull it and rebuild it, I have had good luck with shift kits in these to correct problems like this.
I have used the Superior and Trans-go kits with good results.
Johnny Goode
Jun 28, 2018 08:47 PM
AZmoparguru
Jan 6, 2018 03:04 PM
VX-23 Hokie
Apr 10, 2012 11:20 AM
breakfree
Jul 28, 2008 07:56 PM
txbldr
Jul 16, 2004 09:54 AM
