Tires
Old Dec 31, 2017 | 11:18 AM
bk117wrench's Avatar
bk117wrench
Tires
It's time for tires again. I still run the OEM Firestone TransForce 235-85-16's. I'd like to go a little wider but not change the rims. Is anybody running 265-75-16's on the original 7" steel wheels? I believe a 265-75-16 would be 31.65" tire. The 235-85-16"s are 31" does not look like a clearance issue to me, just wondering if the 265 is ok on a 7" rim.
Old Dec 31, 2017 | 11:22 AM
fordpride's Avatar
fordpride
The 265's fit perfectly. That is what this truck should have come with
Old Dec 31, 2017 | 11:37 AM
z31freakify's Avatar
z31freakify
You can even fit 285/75-16 on it but will have to notch the front bumper like an 1"or 2" and they look better.
Old Dec 31, 2017 | 07:22 PM
madpogue's Avatar
madpogue
Depends. The 265/75 and 235/85 are within 1/10 inch of one another overall height. Wintertime, I'll take a narrower tire over a wider one ("pizza cutter" effect). Not to mention a potential slight fuel edge for the narrower tire.
Old Jan 3, 2018 | 06:43 AM
pwjackson42's Avatar
pwjackson42
I have 265/75/16 on my truck and I love them. The look is just so much better than the 235's. I don't notice any difference in driving with the wider tire other than it doesn't sink into the ground when in soft grass so bad. If I had an F350 I would be on 285's...........that is what I will buy next because I will have a RSK w/ D60 and F350 rear blocks.
Old Jan 3, 2018 | 09:22 AM
madpogue's Avatar
madpogue
For me, if tire A looks 100,000 times better than tire B, and tire B provides 0.000001% better operation than tire A, I run tire B. When I'm looking at my tires, I'm not driving the truck. When I'm driving the truck, I'm not looking at the tires, and I d@mn sure don't care how the truck looks to anyone else. Drivers need to pay attention to the road, not to how one particular truck's tires look on it.
Old Jan 3, 2018 | 09:36 PM
Bluediesel250's Avatar
Bluediesel250
I like my 235/85s. Especially for winter driving. Traction is way better than a wider tire and when they get some miles on them I can swap them on to my trailer that has the same size tires to burn them off there. That way I can keep pretty good tires on the truck all the time
Toplait
Nov 15, 2012 04:32 AM
84-250
19
Sep 7, 2011 07:46 PM
mobecker
1978 - 1996 Big Bronco
Jan 9, 2009 11:32 PM
paintslinga2010
Jun 10, 2007 01:46 PM
