Wheel offset
Old Dec 30, 2017 | 08:38 PM
mxer0022's Avatar
mxer0022
Wheel offset
Ok guys so I'm a little confused as what offset I need to get if I plan on lifting 4" with 35X12.5R20 tires. I'm trying to keep the tires either flush or max 1" outside of fenders. I'm undecided on whether or not I want to get pocket hole flares or not.
Also I've been throwing around the idea of going up 6" with 37X12.5R20. Is there an offset I could get that would accommodate both sizes without rubbing?
pics would be awesome to help me make up my mind. My truck is the platinum with platinum tri-coat paint.
Old Dec 30, 2017 | 09:33 PM
TooHuge's Avatar
TooHuge
My 6.7 has a 4.5 inch carli lift, 20x9 wheels with 0 offset, and 35x12.5 tires. The tires stick out about 1/2 inch past the factory fender flares.
Old Dec 31, 2017 | 12:01 AM
mxer0022's Avatar
mxer0022
how much clearance do you have with the 0 offset?
Old Dec 31, 2017 | 12:25 AM
TooHuge's Avatar
TooHuge
Lots of room. I could fit 37's easy. There's a couple inches of space between the edge of the tire and the back inner fender when my wheels are cranked all the way.
Old Dec 31, 2017 | 10:18 AM
cangim's Avatar
cangim
I went with +1mm on fuel 20x9, LT295/65r20, not even close to rubbing, I don’t think you’d have any issue with a 37
Amicus
Apr 23, 2018 01:59 PM
Warbird66
Sep 3, 2012 11:08 AM
bla1879
1997 - 2003 F150
22
Jan 29, 2008 12:11 AM
scram98400jm
Nov 7, 2003 03:29 AM
steverowe
1966 - 1977 Early Broncos
Feb 25, 2003 09:05 AM
