1966 - 1977 Early Broncos
Wheels for uncut '68
Old Jan 26, 2003 | 12:56 PM
steverowe's Avatar
steverowe
My Daughter has a '68 that hasn't had the rear fenders cut. We put a 2.5" lift kit on it and 15x8 Eagle Baja wheels with Goodyear 235 MT/R's. The offset on the wheels causes the rear tires to run real close to the fender opening lip. In fact, we originally put 30" MT/R's on it and had to swap them because once it was off level, one of the rear tires would rub.
Any suggestions for a similar wheel that would reduce the offset and pull the tires inside the fender opening?
Thanks.
Old Jan 27, 2003 | 12:35 AM
RCrawler's Avatar
RCrawler
Go with the same wheel in a 7" width. This will fit the 235 better and should bring the tire in a little more with the right offset. They will also fit the 30x 9.50s too. You should be able to try a set of them on with the tires you want to see if they will clear, at a good tire shop.
Jason
Old Feb 25, 2003 | 09:05 AM
built4wheelin's Avatar
built4wheelin
i run stock rims (15x7 4" BS) with 32x11.50's on my '68 with UNcut fenders. it has a 3" body lift.
also ran 33x9.50's on my '74 with 3.5" lift and UNcut fenders on stock rims.
callmebobvilla
Jan 9, 2015 07:22 AM
78Fordbc
Feb 19, 2014 06:38 PM
redbull660
Apr 23, 2012 09:42 PM
NicoDeLorenzo
Apr 26, 2011 08:59 PM
Ford-Trucker84537
Paint & Bodywork
Jul 9, 2004 12:11 PM
