F-100 1973 (351 Cleveland)
I have a 1973 F-100. I had the motor rebuilt it and found it had a 1972 351 Cleveland in it -- 2V "H" code.
What was the original motor in my truck?
I had the motor rebuilt where they shaved the heads 0.10, bored it 30 over, I have a 600 4 barrel on it with an edelbrock 4 bbl into 2 bbl heads in-take manifold and have this cam in it:
Cam lift .281 (Int) .296 (exh)
Valve lift .486 (int) .512 (exh)
Lobe Ctr: 106 (int) 118 (exh)
SAE Duration 282 (int) 292 (exh)
.050 Duration: 204 (int) 214 (exh)
How much did all of this raise the horsepower do you think?
The original timing was 4 BTC. It seems way too retarded. What should it be now?
Alex
Alex
on
The increase in HP could be +/-5%.
Could be more if the pistons were changed from dish to flat top say.
5% doesn't sound like much, but you should feel the extra power once the timing is corrected.
The cam, compared to the OE specs, will make a nice difference.
4 degrees BTDC is robbing power !
Try 10 degrees.
Then try 12 degrees and 14 degrees.
But don't let your total timing exceed 34-36 degrees.
Go for test drives after each small change, and you'll soon get a feel of what the best setting is.
Try 10 degrees.
Thank you on the timing. I set it to 10 btc. I run it on ethanol free 90 octane. The pistons are stock about 8.6 to 1. I am guessing it raised the hp about 15 or so like you said. I had a choice to go with 10 to 1 on the rebuild. I did not but should have.
The motor in there now I think is a 1972 351C 2v that was about 240 hp stock and out of a Grand Torino. My guess is the original was a 360 CI.
Thank you both.
Thank you both.
Yes at 4 BTDC it was about to stall. So I moved it ahead and then wrote the initial post above.
It would have only cost me an extra $100 for the 10 to 1's and I should have did it. It is a work truck (had 2,000 lbs in it yesterday) and I thought, stock plus a bit was all it needed. Needs vs wants.
Thank you again and happy new year.
BGF100
13
10-23-2017 07:05 PM
J Hodges
03-19-2008 01:50 PM
jimbo beam
10-21-2006 12:02 PM
longjohn69mustong
02-02-2004 04:20 PM
blaxuede
26
02-28-2001 11:40 AM
