Sponsored by: Innova
Installing Android stereo in Excursion need help with SWC wiring
Old Dec 30, 2017 | 03:05 PM
PaulMedik's Avatar
PaulMedik
I am installing an Android stereo (Brand = Pumpkin) in my 04 Excursion and want to use the existing steering wheel audio controls for volume etc. My Android has K1 and K2 wires for SWC, but I am not sure where to connect to my Ford harness. I have pin 18 tapped on the unused Ford connection, but which wire do I connect to pin 18?
Left one connects to wiring harness adapter, but right hand has no adapter. Pin 18 on right hand is the one I have tapped, but not sure...
Old Dec 30, 2017 | 03:08 PM
PaulMedik's Avatar
PaulMedik
This is the unit I am installing
CLICK HERE CLICK HERE
Old Jan 1, 2018 | 04:10 PM
madsonp's Avatar
madsonp
You might give these guys a call and see if this will work for your system. https://pac-audio.com/catalog/radio-replacement/swi-rc
Old Jan 1, 2018 | 04:50 PM
PaulMedik's Avatar
PaulMedik
madsonp,
I tried a
Metra Axxess ASWC-1 Universal Steering Wheel Control Interface Metra Axxess ASWC-1 Universal Steering Wheel Control Interface
on two other systems I installed, but it didn't work.
I did get my android to work though:
Connect Key1 to Pin 18 and then Key2 to chassis ground. Then go to the steering wheel program screen and hit start then choose each control that you have and hit the corresponding button on your steering wheel. In my case I only have vol +, Vol -, Next, and Mode. Works PERFECT!
The android systems aren't plug and play, but they are way better than Jensen and of course better than stock. Radio reception is much better than stock radio. It's nice to have google maps for navigation and full web access via wifi as well.
Old Jan 15, 2018 | 12:41 PM
530ktmpilot's Avatar
530ktmpilot
Had same issue on 06 f250. Just moved one of the unused wires from the adapter to pin 18 and only connected key 1 wire from andriod unit. As said above, easy to program buttons on the swc menu after that.
MILAGRO33
Mar 28, 2019 10:16 AM
chetspencer
May 28, 2018 12:56 PM
ShelbyHauler
Dec 25, 2017 12:20 AM
nagetech
Jul 15, 2015 10:58 PM
DanzbigA250
Oct 15, 2009 12:01 AM
