I have a 2016 F 350 with 50,000km on it
I have a cracked and inactive nav screen.
The crack started on the bottom of the screen below where it’s even visible and cracked straight up.
Since then I have tried to press the screen to active heated seats etc and it’s now completely spider webbed with cracks and won’t work at all.
i called the service dept and was told it’s very unlikely that it will be covered under warranty ???!!!
Its going to be several thousand to fix it.
Has anyone else had this issue??? Was it covered under warranty ??
Thanks
Thanks
I have not had this issue but you can go to 4dtech.com and they`ll be able to hook you up with another/replacement screen for around 400.00 and not the thousands that you were thinking and yes, replacing it yourself is very, very easy.
