Intake compatibility
Old Dec 30, 2017 | 01:52 PM
dboy67's Avatar
dboy67
Hey Guys, Need some help figuring out which Intake will replace mine that is cracked.
Truck is a 65 F250 4x4 with a 352. Wanting to go stock cast and keep the 2bbl carb.
Vin Plate
Crank#'s
Head#'s
Intake#'s
Intake crack
Thanks for the help!
Old Dec 30, 2017 | 02:13 PM
6t6merc's Avatar
6t6merc
I think any FE 2V intake will work. Unless my memory fails me and there is a 2V with cast-in EGR passages, which you don't want. Your truck isn't "numbers" correct so year doesn't matter. You want any early ('65-up-ish) one, but not so early it has a road draft tube.
You could have had mine for free. I threw it on the scrap pile (I can't throw one farther than that) when I installed an aluminum Edelbrock. I swore I would never struggle with an iron one by myself again, and so far I haven't.
Eric
Old Dec 30, 2017 | 02:21 PM
dboy67's Avatar
dboy67
Eric
Good info, Thanks! So what vehicles would I find a FE 2V intake on and what should I look for to identify it as one that will work? I realize the heads are from a 67 Galaxie and the intake is probably original being a 65.
Old Dec 30, 2017 | 05:15 PM
6t6merc's Avatar
6t6merc
Look for a pickup about '65 to '73 or so. They're in cars too but not so many are FE 2v.
Old Dec 30, 2017 | 06:29 PM
User 71024's Avatar
User 71024
Eric
Road draft tube isn't a problem, just make a blockoff plate out of aluminum or steel.
Old Dec 30, 2017 | 09:28 PM
matthewq4b's Avatar
matthewq4b
Trucks till 1976. Full and mid size cars till 1971
Old Dec 31, 2017 | 07:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1965 F100/350 352 without PCV: Road draft tube fits into the hole at the rear of the right valve cover.
With PCV: Smog valve fits into this same hole. Both use a rubber grommet. All 1966 and later have PCV
No EGR valves until 1973.
2V intake manifold interchanges: 1965/67 F100/350 352; 1968/72 F100/350 360/390 // 1965/67 Ford Passenger Cars 352/390; 1968/71 Ford Passenger Cars 390.
Old Dec 31, 2017 | 07:19 PM
James_Western_Canada's Avatar
You shouldn't have too much trouble finding someone swapping to an aluminum 4bbl intake, but they will need to be fairly close by, because even if they were giving the manifold away, shipping it could get expensive, cuzz they are NOT LIGHT.......
James
Old Jan 1, 2018 | 11:10 AM
daveengelson's Avatar
daveengelson
First and Foremost, welcome to FTE!!If unable to locate thru local salvage, or possibly Craig's list. If you have an ebay account they occasionally come-up. I have it set up to receive daily ebay email notices when an item of interest is place for 'auction', or 'buy now'.
https://www.ebay.com/itm/Ford-fe-int....c100005.m1851
https://www.ebay.com/itm/Ford-FE-Big....c100005.m1851
https://www.ebay.com/itm/FORD-390-36....c100005.m1851
Again welcome, looking foreward to your input and post pic's when you can!
PowerstrokeJunkie
Oct 24, 2007 04:31 PM
Cobra330
2004 - 2008 F150
Jan 22, 2006 07:18 PM
cudaz101
Oct 21, 2005 01:06 PM
jstandle
15
Dec 24, 2004 04:52 PM
