1978 - 1996 Big Bronco
exhaust system
Old Sep 13, 2003 | 12:50 PM
debayfishing's Avatar
debayfishing
exhaust system
what doe you think, doe you gain anything besides looks with cat back dual 3 inch or 2 1/2. or just go with 2 1/2 inch Single and save the money and still have a good sound?Going with a magnaflow muffler
Old Sep 13, 2003 | 01:05 PM
DW2455's Avatar
DW2455
exhaust system
a tuned single exhaust system will flow well, its more preference than anything, there are some that will tell you duals will rob you of low end tork, but that only if you use pipes that are to large, if you put a big enough of a pipe on a single, it will scavenge your low end tork as well. Hope this helps. Good Luck DW
Old Sep 13, 2003 | 06:50 PM
debayfishing
exhaust system
Thank you Dw for you input ,Going to the muffler shop tuesday cant wait.
Old Sep 13, 2003 | 07:31 PM
WhëëlMå1's Avatar
WhëëlMå1
exhaust system
I would definately stick with a single mandrel bent 3" pipe. Running duals on a bronco is pure silliness. If you use the search function, you will probably understand what I am talking about. Are you merely upgrading the catback section, or the whole shebang?
Rich
Old Sep 13, 2003 | 08:31 PM
debayfishing
exhaust system
just upgrading from the cat back to get some sound!!!!! was ~~~~~~~~ to see if the duals where worth the extra money?? Or maybe just replace the muffler and add ss tips.
Old Sep 13, 2003 | 08:58 PM
WhëëlMå1's Avatar
WhëëlMå1
exhaust system
What kind of sound are you looking at getting? I love my bassani cat back. Its loud when you get into it, but can pass as a 'sleeper' when sitting at idle and going around town. The cheapest alternative is to add a high flow muffler and a bigger tip, but I have always found that larger diameter tubing (3" specifically) has added quite a bit. Just my opinion.
Rich
Old Sep 13, 2003 | 09:07 PM
DW2455's Avatar
DW2455
exhaust system
Rich
you know everyone is entitled to there own preference and opinions, but to insult someones inteligence by saying (its pure sillines) to put duals on a bronco, makes you just a silly for saying so, shurly anything can be upgraded, but some of the worlds fastes production cars run a TRUE (tuned dual exhaust) systems, any unrestriction you do a exhaust system will improve performance to a point. but a single system on a (V) engine will never out flow a TRUE dual system thats tuned. DW
Old Sep 13, 2003 | 09:31 PM
debayfishing
exhaust system
WheelMa1 I f you go to Magnaflow.com they have a sound bit there sounds good to me ,And it Still will pass inspection here delaware.Dw Local muffler shop said they could put duals on from the cat back -2-1/2 pipe, Magnaflow muffler and ss tips, life time muffler for 300.00 price sound to high??
Old Sep 13, 2003 | 09:55 PM
WhëëlMå1's Avatar
WhëëlMå1
exhaust system
If you are to run duals, plan on NEVER opening your rear window while you are driving. The exhaust fumes will surely overcome you due to exhaus location and vacuum pressure of the cab, and did I mention it is very bad for your health? I know at the stock location of the exhaust, I can still pull exhaust in. Yes, many high performance cars can run duals with good results. How many of them have a rear power window? Its nothing to due with the performance of it. Yes, you might get better performance out of duals, but riding in it might be another story. Thats all that I was saying.
Rich
Old Sep 13, 2003 | 10:09 PM
DW2455's Avatar
DW2455
exhaust system
Go to my gallery look under tech stuff there are pics of how mine is done. Now i cut and removed my old pipes and installed the muffler my self, and they run the tail pipes and welded on the tips. my whole system cost $225-250 total including the muffler,
Now look at mine, cause if you run them straight out the back, then you will get exhaust fumes in the cab if you open the back window, so if like to cruise with the back windo open then have the pipes turned out the sides behind the tires and you wont have any problems,
.I run mine straight out the back simply for personal preference, the only time i ride with my back window down is when i remove the top, so it dosent matter, other wise my windows are up and A/C is chillin. but any way take a look at mine and make your own choice. Good Luck. DW
Old Sep 13, 2003 | 10:23 PM
DW2455's Avatar
DW2455
exhaust system
wheelMA1: no problem, i guess it just sruck me wromg cause i dont care anything about letting my back windo down unless i take the top off, or need to open the tail gate, its just a personal thing with me, i rather chill in th a/c stylin and proifilin, i cant take the lady out on the town with the windows down getting all hot and messing up her hair doo. Whew i gota stop this. DW
Old Sep 14, 2003 | 11:33 AM
debayfishing
exhaust system
DW, went to your gallery thats a clean setup!!! if i go duals only thing that i will doe different is run the pipes out the sides behind the tires because i doe like the window down on nice days.
Old Sep 14, 2003 | 01:09 PM
DW2455's Avatar
DW2455
exhaust system
Thats cool and easy enough to do, they could have easily took my system and put a 45dgr bend in them and kicked them out the sides. Like i said theres nothing wrong with it either way, it nice to get ideas, and advice, but the best advice is do the way YOU want it. DW
P.S. thanks for the compliment
Old Sep 16, 2003 | 08:25 PM
debayfishing
exhaust system
Well I got magnaflow today sounds great,went with single 2.5 exhaust 45 degree behind the tire tucked up tight so you cant see it hanging down behind the trucks bumper with a 304 stainless steel, 3 .5 resonated tip. Boss man told me they could put duals on but i would have to signe of being so close to the abs sensor and the fuel line.wanted duals but hey i can live with this. Nice deep tone!!! just like there web site best part is Boss man said bring truck back before inspection the will fix me up no charge!!!!
Old Sep 16, 2003 | 09:49 PM
Capone's Avatar
Capone
exhaust system
I had a bigblock 2 chamber flowmaster installed on my 5.8 Bronco, the muffler takes a 3 inch pipe from the cat converter, splits the sound into to two 2.5 inch pipes that are mandrel bent and turn behind both rear tires....and of course a nice stainless tip on each side.
great sound, mellow idle, screaming @ WOT
lost a little bit of throttle response but gained 1 mpg fuel mileage wise
the truck will climb hills much easier when cruising (before the exh upgrade it had trouble doing so)
Another good result was the engine bay temps went down quite a bit....due to the unrestricting of the exhaust flow.
to finish the exhaust in my ride off I will install the thermal barrier coated Bassani Y pipe effectively removing the stock resonator, this should make the truck a bit louder and throatier.
I like it.
