1976 f350 flatbed
Single cab. 390, 4 speed.
Amd yes, Ford did produce behind the seat fuel tank models in 76, but only for flatbed trucks. Any help appreciated. Thank you.
this page shows two tanks, looking like the difference is the length of the fill tube, and one appears to have an extra spout. Good pictures might help you.
The following is correct:
D0TZ-9002-A (replaced C1TZ-9002-K) .. 19.5 Gallon In-Cab Fuel Tank.
1961/66 F100/700; 1963/69 N/NT500/750; 1967/69 F800/1000; 1967/72 F100/750 (except as noted below).
This tank is reproduced by Blue Oval Truck Parts (Anaheim CA) that sells it to the other repro parts sellers and the general public.
D1TZ-9002-A .. 18.5 Gallon In-Cab Fuel Tank.
1971/72 F100 with the Evaporative Emission system.
*1973/77 in-cab fuel tanks: F250 4WD (High Boys) & F350/750 Cab & Chassis.
D3TZ-9002-F .. 19.5 Gallon In-Cab Fuel Tank-Use without Evaporative Emission / Obsolete
D3TZ-9002-G .. 18 Gallon In-Cab Fuel Tank-Use with Evaporative Emission / Obsolete
do you know how this tank mounts at the bottom?
i See some threaded holes in the floorboard behind the seat, but no holes in the back wall of the cab toward the bottom to bolt to. I can see that it mounts to the back of the cab at the top of the tank, but I don’t see how it mounts at the bottom. Maybe I’m missing a bracket of some sort in the bottom behind the seat that the tank mounts to? Thank you.
