Fuel Separator leak?
Old Dec 26, 2017 | 05:35 PM
dcara's Avatar
dcara
Started getting getting a 2 second drip for about 5 minutes under my 99F250 7.3 just forward of center of the engine when I turn it off. Smells like diesel and feels like water. Thoughts and comments appreciated.
Old Dec 27, 2017 | 07:52 AM
Tom's Avatar
Tom
Since this is a diesel-specific question, I'm moving this to the 7.3L forum. You should get some better replies down there.
Old Dec 27, 2017 | 08:36 AM
Colorado350's Avatar
Colorado350
If you look at the back of your fuel bowl you'll see a yellow lever that is the drain, with a flashlight you can can see the drain tube. If you crawl under your truck near the passenger side of the front axle you'll see the 3/8 tube, that is the drain tube for that lever. That lever housing is a known place for leaks. You can buy the orings from Clay and simply replace them. Probably a good time to replace your fuel filter too if you haven't in a while. s
Old Dec 27, 2017 | 10:12 AM
pirschwagon's Avatar
pirschwagon
Fuel System - 7.3L
Old Jan 2, 2018 | 05:10 PM
M-S-G's Avatar
M-S-G
Get yourself this kit
Complete Fuel Bowl Seal Kit for Ford 7.3L (99-03) - GZ-7-003
Most likely you only need to replace the 4 bolts holding the black and yellow valve. This is easy to do and does not require removing the fuel bowl.
Work or Play?
Aug 4, 2019 12:15 AM
queen of spades
May 7, 2015 09:45 AM
vczar1
Jan 21, 2013 10:40 PM
afonda
16
Dec 1, 2008 08:08 PM
KrenzyRyan
13
Nov 30, 2006 12:29 AM
