Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
need help pls
Old Dec 26, 2017 | 01:18 PM
Kevin2017's Avatar
Kevin2017
need help pls
I was driving and the oil cap was off oil went everywhere and then it cut out so I top it up with 5l off oil it got me bk now will not Turn over
Old Dec 27, 2017 | 12:18 PM
PupnDuck's Avatar
PupnDuck
It's likely the engine is toast. The oil pressure light never came on? It might have gotten you home but once it cooled, it was all over.
Old Dec 27, 2017 | 12:49 PM
Kevin2017's Avatar
Kevin2017
No it started Again but when it got hot it stopped and now it’s cold it’s turning over again so I’m puzzled
Old Dec 27, 2017 | 02:13 PM
PupnDuck's Avatar
PupnDuck
It ran out of oil. Probably wiped the rod and main bearings and scored the crank and the cylinder walls and rings. Depending on the type of lifters may have scored up the cam lobes as well.
If you can get it to crank, do a compression test.
Generally, when a hot engine stops running from lack of oil you're looking at a rebuild / replacement. You'll have to decide if its worth it.
Old Dec 31, 2017 | 10:56 AM
Chuck's First Ford's Avatar
Chuck's First Ford
What he said.. unless the battery died also.
its like a human without blood... dead. (bleed out) metal on metal.. grinding and grinding.
even "IF" you can get it started.. its damaged.
Old Feb 5, 2019 | 10:22 PM
kendall69's Avatar
kendall69
I had two vehicles lose oil. One I got a hole in the pan and didn't know car started knocking. Fixed the pan filled it up it went for another 60K just fine till I traded it in. Same thing happened with a work truck. Employee ran it dry knocking, mechanic said engine blown. I filled it up and that one went another 100K no problems no noise.
It's not always blown if you run our of oil.
rbond
13
Aug 5, 2019 10:18 AM
240inline
Dec 1, 2015 02:12 PM
rmalottwtes30
Oct 11, 2010 09:58 AM
gangstakr
37
Sep 25, 2009 12:58 PM
FERacing66
Oil & Lubrication
Apr 1, 2004 11:52 AM
