Dumb radiator question
Old Dec 26, 2017 | 09:39 AM
LipRipper3006's Avatar
LipRipper3006
I don't know where you heard this but it's not true.
https://community.cartalk.com/t/why-...-winter/5052/2
Old Dec 26, 2017 | 09:55 AM
Franklin2's Avatar
Franklin2
Originally Posted by LipRipper3006
That place is full of mis-information. What little bit I read, the guy is talking about
In the old days, many of us filled the radiator with water in the summertime. At 180 (or 195) degrees, the water is well on its way to boiling. Therefore, we would put in a 160 degree thermostat. In fact, some people ran their vehicles without a thermostat.
which is untrue also. He does not understand how a cooling system works. The reason you run a radiator cap that builds pressure in the system is to raise the boiling point. The boiling point of water is 212F at sea level. If you raise the pressure, the boiling point goes up. So he was no where near boiling over like he thinks.
Here's a calculator that you can plug numbers in to play with the boiling point. At sea level the atmospheric pressure is 14.7(select psia as your units) If you plug in 14.7, you get a boiling point of 212F
https://www.engineeringtoolbox.com/b...ter-d_926.html
A lot of the very old cars ran a 7psi cap. If you plug in 14.7+7=21.7 and that gives you a boiling point of 232.2F
My diesel and some of the later trucks ran a 13 psi cap. 14.7+13=27.7 and that gives you a boiling point of 245.8F
A lot of the modern cars and trucks run a 16psi cap. 14.7+16=30.7 and that gives you a boiling point of 251.7F
Old Dec 26, 2017 | 09:59 AM
LARIAT 85's Avatar
LARIAT 85
I agree with Franklin - that's simply not true.
For the record, I run a 195* thermostat in my carbureted 1985 Ford F150. I live in the South East, where temperatures in the Summer are often well above 100* and humidity even worse. I never change out my thermostat and I don't have any issues.
Old Dec 26, 2017 | 10:06 AM
FirstFord1994's Avatar
FirstFord1994
Will be working on it this weekend thanks for all the advice and help guys just a few more questions
do I need a radiator shroud
Is there a cap I can use instead of hose and a plug
Old Dec 26, 2017 | 12:14 PM
LipRipper3006
The shroud is really up to you, doesn't serve much for cooling, more of a safety thing. Around here the old timers still swap out their thermostats as they swear by it. Not sure if they run water in the summer but I doubt it. When you swapped for your winter tires you got a new thermostat and maybe a set of chains with your oil change. But for the shroud, I would personally get one, protects fingers and toes along with hoses and wires for not much money from NPD.
Old Dec 26, 2017 | 02:55 PM
Franklin2's Avatar
Franklin2
The fan shroud is very important. The further away the actual fan blades are from the radiator, the more important it is. When the fan is pulling air, the air would much rather come in from the sides in the engine compartment rather than coming through the radiator, so it will over heat in city driving without the shroud. The 300 six is going to be the only engine that might have the fan close enough that you could get away with it, but I would not count on it working very well.
Old Dec 26, 2017 | 04:49 PM
FuzzFace2's Avatar
FuzzFace2
Dave F. got it all right.
I would plug that line and test the system as the truck is new to you so you can see if anything else shows up like needing a shroud.
BTW for 81 300 six LMC list 2 for that truck and you need the numbers off the old shroud. I think why the 2 is early & late and your radiator would be a late shroud but could be wrong.
I know this because I don't have a shroud for my 81 300 six.
Dave ----
Old Dec 26, 2017 | 05:15 PM
maytag906's Avatar
maytag906
I've seen rubber "caps" at auto parts stores, that are held in place with a clamp.
Old Dec 27, 2017 | 05:37 AM
FirstFord1994
Found some caps thanks everyone for all the help but I do have another question I ordered a rebuilt carb for truck it has only a hot air choke my current carb has hot air and electric choke will that be a problem using just the hot air choke ???
Old Dec 27, 2017 | 08:37 AM
ctubutis's Avatar
ctubutis
Fonzie beat me to it and he is right about the 2 tubes coming out the filler neck.
Top one is for the coolant recovery tank.
Bottom one is part of the throttle body heater setup used on EFI models.
Old Dec 27, 2017 | 08:44 AM
Franklin2's Avatar
Franklin2
Should work ok if your hot air pipe is not rusted out and has vacuum on it. The electric is just an assist to help it open up quicker in warmer weather. So that will only come into play in the summer, and you can probably make a quick adjustment on it if necessary then.
F1snob
Mar 13, 2016 10:11 AM
Steelheader87
Apr 2, 2012 03:18 PM
cajunsuperduty
Jul 10, 2011 07:02 PM
bhubin
Jun 5, 2011 02:42 PM
CowboyBilly9Mile
Dec 4, 2004 04:12 PM
