Need Help!!
Old Mar 31, 2012 | 04:35 PM
Steelheader87's Avatar
Steelheader87
Need Help!!
I replaced radiator last year due to coolant loss, it had a small hole in it, it was only leaking when put a lot of pressure to it. Anyways, I am losing coolant out of the overflow tank. It seems to push it into the tank, but not suck it back into the radiator. Only does this when I am pulling the fifth wheel hard. When running empty, no problems. The line from the radiator to the tank is good. I replaced the cap before realizing the radiator was bad, but bought a cheap one at Napa. I am thinking of going to Ford and replacing it again and see what happens. Any solutions? Thanks for your advice.
Old Mar 31, 2012 | 10:17 PM
91dirtydiesel's Avatar
91dirtydiesel
13 lb cap?
Old Apr 1, 2012 | 10:17 AM
Phy's Avatar
Phy
Dumb question: The tube from the radiator to the overflow tank extends into the tank down to the bottom, correct? If not, it will suck air instead of coolant...
Old Apr 2, 2012 | 12:50 PM
rolape2's Avatar
rolape2
Had the same problem when I eplaced the radiator. Used the new cap that came with radiator. When I put the old cap on it was fine.
Old Apr 2, 2012 | 03:18 PM
38Chevy454's Avatar
38Chevy454
Could be just a defective cap. It is probably just getting hot and the amount that is coming out during the long pulls should suck back once it cools down. Make sure the hose is sucking liquid not air as Phy suggested.
F1snob
Mar 13, 2016 10:11 AM
61 uni
Nov 16, 2012 07:22 PM
caseys
Oct 22, 2011 10:23 AM
CowboyBilly9Mile
Dec 4, 2004 04:12 PM
SteV8e
Jul 29, 2004 07:45 AM
