Sponsored by: Real Truck
Crew Cab Body bushing replacement
Old Dec 25, 2017 | 08:23 AM
Firefighter 1406's Avatar
Firefighter 1406
Well I had to replace the radiator yesterday and the top nuts for the front body bushings are accessible when the radiator is out. So I went for it. I have ordered the standard Daystar kit a while back. The front two by the radiator were a huge pain to get the bolt out and to get the clamshell separated. Rest of the passenger side was cake. Drivers side position 1,2 and 4 went smooth. Position 3 on the other hand I hate. It’s basically right where the two doors come together in a crew cab. I work on that bushing for 2 Hours trying everything I could think of. Removed the bolt no problem. I had to give up and get the radiator back together. The top of the bushing is still intact so it will just have to ride that way for now. I am gonna have to order a new top and bottom piece and cut the old one out. Very frustrating for sure.
The advice I was given to hear each bolt with a torch for 1 min before trying to break them loose worked great.
Lesson to be learned prepare that this will take a lot longer then you would think.
Old Dec 25, 2017 | 09:27 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Heat is a GREAT lubricant. when available . access can be a problem.
Old Dec 25, 2017 | 08:49 PM
Firefighter 1406
Anybody know if you can order the metal parts of the body mounts separate?
Old Dec 26, 2017 | 06:19 PM
Firefighter 1406
Just a small update. The bushings from Ford are ordered top metal with bushing and bottom with bushing. You cant just buy the metal pieces. So I paid $80 for both and gonna throw the new bushings in the trash.
jrlaidle
Jul 27, 2017 03:14 PM
JayzDaddy
May 24, 2013 07:10 AM
SideWinder4.9l
Apr 14, 2013 10:21 PM
bucks77ford
Jun 23, 2006 02:05 PM
95F250NUT
Offroad & 4x4
Jul 20, 2004 04:21 PM
