2009 f350 quad cab. Radiator support and third bushing back (the odd sized one at the B pillar) aren't coming easy. I got one of the radiator support bushings apart but the rubber was gone on that one so i used a hammer and the upper portion was metal to metal with the frame so it moved. The others still have rubber so it us cushioning the hammer blows and not allowing it to separate. I cobbled together a puller but the strong back is bending. Any suggestions? I really don't want to cut them out. The one at the front floor board and the rear one came right off with a pry bar.
I used a slide hammer loaner from AutoZone. However, my truck is leveled with 37" tires so I have the clearance. If you have raps to pull your truck up on to, it will work.
