I was planning on using some polyurethane cab mount bushings with my existing hardware for my 77F250, but kits only come with the cab mounts. Does anyone make polyurethane bushings for the radiator support? If not, will there be any alignment problems with regular rubber bushings for the radiator support? Also, can you buy bushings for just the radiator support? LMC offers the entire kit with hardware, but I already have hardware, I just need bushings. thanks for any help.
I just did this on my '79 had to make my own hardware, rubber bushing took several j yard visits as long as the sandwich size is the same you can make some out of nylon.
The Energy Suspension cab mount kit I bought came with bushings for the cab mounts and the radiator support. I have the part number at home if you need it.
