FE ID
Old Dec 24, 2017 | 04:27 PM
C Rm's Avatar
C Rm
FE ID
Found a FE for sale.The guy says its a 390,But it has 352 cast numbers on front of block,im not sure how to ID the different FE engines.Can anyone help me with this issue.
Old Dec 24, 2017 | 05:38 PM
fe390pc's Avatar
fe390pc
From the outside it is tough as most of the blocks are cast with 352 on them. The best way to verify the size is to remove a spark plug and measure the stoke using a rod or dowel.
Here is a list of the most popular FE Engine sizes.
FE/FT engine displacements Displacement Type Bore+0.0036/-0.0000 Stroke+/-0.004
352 cu in (5.8 L) FE 4.0000 in (101.60 mm) 3.500 in (88.9 mm)
360 cu in (5.9 L) FE 4.0500 in (102.87 mm) 3.500 in (88.9 mm)
390 cu in (6.4 L) FE 4.0500 in (102.87 mm) 3.784 in (96.1 mm)
406 cu in (6.7 L) FE 4.1300 in (104.90 mm) 3.784 in (96.1 mm) 410 cu in (6.7 L) FE 4.0500 in (102.87 mm) 3.984 in (101.2 mm) 427 cu in (7.0 L) FE 4.2328 in (107.51 mm) 3.784 in (96.1 mm) 428 cu in (7.0 L) FE 4.1300 in (104.90 mm) 3.984 in (101.2 mm)
Old Dec 24, 2017 | 06:15 PM
351Cleveland C4's Avatar
351Cleveland C4
You HAVE to measure the stroke. If you can't, just bet on it being a 360.
Old Dec 24, 2017 | 07:23 PM
mrollings53's Avatar
mrollings53
If the oil pan is off you can also just look at the casting number on the crank.
Ford FE Crankshaft Casting Numbers - FORDification.com
Old Dec 27, 2017 | 09:30 AM
DirtyFerd's Avatar
DirtyFerd
I don't know how accurate this is, but if the engine is out here is something else you can check
https://www.ford-trucks.com/forums/8...390-crank.html
Old Dec 27, 2017 | 05:45 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by C Rm
Found a FE for sale. The guy says its a 390, but it has 352 cast numbers on front of block.
I'm not sure how to ID the different FE engines. Can anyone help me with this issue?
The 352 is a foundry mark, has nothing to do with the actual engine size, because all FE engines were cast as 352's.
It might be a 352, but it could also be a 360, 390, or a 410 or 428.
On sale day, 352/360's magically become 390's!
Measure the stroke to verify engine size: 352/360: 3.50" / 390: 3.78."
Old Dec 29, 2017 | 05:10 PM
C Rm's Avatar
C Rm
thank you guys I do appreciate the info
Cap'n Tea Bag
Jun 3, 2019 10:37 AM
Nick-1973-ford
Jul 14, 2016 08:30 AM
smoker9000
Nov 9, 2005 12:41 PM
400Nut
Jun 20, 2004 10:16 PM
Spudco
17
Feb 12, 2003 06:23 PM
