Turn Signal Issue
Old Dec 22, 2017 | 10:24 AM
JadedEX's Avatar
JadedEX
Turn Signal Issue
I just bought a 2000 Excursion. The left rear turn signal is rapidly blinking and the front turn signal doesn't work when you signal or use the hazards. However, it does flash on when I lock the truck, which shows me that i have power to the socket. That being said, the left arrow on the cluster in the truck doesn't flash when you signal or use the hazards. Is that bulb part of the circuit that would cause only the front signal not to flash, or am i looking at a MFS?
ETA: Yes, i've already replaced the two front signal bulbs to verify that they weren't the issue, lol.
Thanks in advance for any help or input!!
Old Dec 22, 2017 | 04:58 PM
Franklin2's Avatar
Franklin2
I suspect the multifunction switch or wires that are being pulled on inside the column. Tilt the wheel radically one way and see if there is a change.
jssjr1955
Oct 9, 2016 04:15 PM
Island'r
17
Jan 4, 2014 07:27 PM
69 F100 Cali
Feb 6, 2012 05:15 AM
greenterror
Electrical Systems/Wiring
Apr 9, 2004 06:58 AM
00Expo&73Bronco
Jul 18, 2003 08:55 PM
