Reference voltage issue.
Old Dec 21, 2017 | 07:33 PM
Evans88's Avatar
Evans88
My shop recently got a new scanner and today I was playing around with it on my 1994 f150 5.0. Our old scanner could never communicate with the damned thing so it was interesting to see some actual codes and data. Anyways one of the data pids was VREF. Sitting at what I believe to be an unhealthy 6.68v. Usually I see other cars at 5v flat. What would cause this? Ecu issue is my first guess but I’m not coming up with much for info. Any thoughts?
Old Dec 21, 2017 | 11:36 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
How the hell can you get PID data on an OBD1 truck? If you have some magic scan tool tell me where I can buy one please!
Old Dec 22, 2017 | 12:00 AM
mrollings53's Avatar
mrollings53
It is a 302, they received OBDII in some applications before '94. Could be a transplant, or modification.
Old Dec 22, 2017 | 07:22 AM
subford's Avatar
subford
If you have wires going to pins #1 & #3 of the self-test EEC data connector you should be able to read data with the right OBD1 scanner (not a code reader).
This is the same connector you read the codes with a code reader.
A scan from my 1995 5.0L with OBD1.
A scan from my 1994 7.5L with OBD1.
Using my CP9190/CP9185 scanner.
Old Dec 22, 2017 | 09:35 AM
Evans88's Avatar
Evans88
We just bought the new Zeus scanner from snap on we had an old modi’s but that thing wouldn’t even communicate with some obd1 vehicles. I see both your trucks that you showed scan data on have perfect 5 volt reference! I’m jealous. I’m going to do some more diggin on it tonight. Maybe I’ll rip the pcm out and see how it’s looking inside.
Old Dec 23, 2017 | 09:03 AM
Da_Lariat_Chariot
Dude that's awesome, I might just buy myself one.
Old Dec 23, 2017 | 09:54 AM
subford's Avatar
subford
Note that it also works with the OBD2 system.
ryanbodden2014
6.4L Power Stroke Diesel
Feb 11, 2015 09:43 PM
Blue7.3
Australia Chapter
Nov 4, 2014 07:59 PM
tbugher62
Jan 10, 2014 05:29 PM
TheACN
Jul 20, 2013 03:31 PM
KING
Aug 1, 2008 08:28 PM
