Distributor issues
Old Dec 21, 2017 | 07:43 AM
Copebryn's Avatar
Copebryn
Distributor issues
My 88 f-150 4.9 keeps going through distributors. I will be driving and it will start acting like it's starving for something and becomes week on the throttle. Then the cat will get really hot and the next thing I know the roll pin in the distributor is broken off for the cam shaft gear and I loose spark. This is the 2nd time that this has happened the same exact way. Anybody have any suggestion? Sorry if there is another thread out there like this but I have searched and didn't find one.
Old Dec 21, 2017 | 06:52 PM
'89F2urd's Avatar
'89F2urd
What distributors are you using, or what replacement roll pin? How hard is your oil pump to turn? How hard is the distributor to turn when you have it out of the engine?
Old Dec 22, 2017 | 05:57 AM
Briansshop's Avatar
Briansshop
You say it's the second time it has happened, how many mileage between incidents? Guessing that the roll pin is breaking and the gear is slowly moving on the distributor shaft retarding timing. Heat in the exhaust and low power until it moves enough to shutdown.
Old Dec 22, 2017 | 08:25 AM
arse_sidewards's Avatar
arse_sidewards
Did the distributor gear look damaged?
Remove the cap and gear from the distributor, install the oil pump drive, bolt the distributor down tight using the tab (just like it would be when installed) and tell us whether it turns relatively freely. If it doesn't repeat without the oil pump drive and report back.
mpieratt
Jul 19, 2022 01:21 PM
ARCTIC_RAGTOP
Feb 12, 2011 09:36 AM
Mitchissippi
Mar 27, 2007 10:40 PM
75pup
Mar 14, 2007 02:29 PM
thenipster
Dec 7, 2006 04:30 PM
