Sponsored by: Real Truck
TPMS pressure adjustment?
Old Dec 21, 2017 | 04:28 AM
nickpohlaandp's Avatar
nickpohlaandp
TPMS... anyone know how it works? I’ve got the little garage door opener thing to “train” the system, but what if I want to run 50 psi instead of 70 or 80 (F-250).
I just had new tires and sensors installed yesterday and “trained” the system at 50 psi. All was good until tonight. I just got a “low tire pressure” warning and they’re all still at 50. I must’ve driven 30 miles between yesterday and today before I got the warning. Am I stuck with running 70-80 psi?
Thanks for any help.
Old Dec 21, 2017 | 04:49 AM
seville009's Avatar
seville009
Simpler to just ignore the warning.
I stopped putting the tpms valves in my tires years ago. The warning comes on a few times a year, not continuously.
Old Dec 21, 2017 | 05:05 AM
nickpohlaandp
I’d do that but I get a TPMS fault message every time instart the truck. Wish I could just deactivate the system.
Old Dec 21, 2017 | 10:18 AM
Evan_P's Avatar
Evan_P
What year truck?
Old Dec 21, 2017 | 11:59 AM
nickpohlaandp
Originally Posted by Evan_P
What year truck?
It’s a 2012
Old Dec 21, 2017 | 02:53 PM
cjssr's Avatar
cjssr
If you download the Forscan software from Forscan.org and purchase a obd cable EL327 compatible for about 20..00 you can disable the TPMS and do alot of other things on your 2012. Go to Forscan.org and read up . Software is free and you can do quite a few things with it. Here's a link to spreadsheet for your truck also.
https://docs.google.com/spreadsheets...il&ts=5a3bd76a
Old Dec 21, 2017 | 03:11 PM
nickpohlaandp
Awesome! Thanks man. Will the Forscan mess with the tune I loaded from my Diablo tuner?
Old Dec 21, 2017 | 03:16 PM
cjssr's Avatar
cjssr
It won't affect that. All you will be doing is changing the coding in the BCM. Just remember to backup the as-built configuration before making any changes just in case you mess up or want to revert back to original configuration. Did I metion the Software is free !!
Old Dec 21, 2017 | 03:34 PM
nickpohlaandp
Yeah, I was just checking out the website. I need to look at it on a computer and not my phone... I can’t search as easy on my phone. I sent an email to their contact email address to see what I could do. Where can I get one of those cheap USB adapters?
Old Dec 21, 2017 | 04:16 PM
nickpohlaandp
So many cables to choose from, and it looks like most come with a cd to load the driver. You know of any that don’t require a cd? My PC laptop doesn’t have a cd drive.
Old Dec 21, 2017 | 06:03 PM
cjssr's Avatar
cjssr
OBD CABLE
This the one I used. I am running Windows 10 in Parallels on my Macbook(no cd) and didn't have to load drivers from CD. There are many to choose from but many are poor china knockoffs from original chipset that Forscan needs to work properly.
https://www.google.com/url?sa=t&rct=...s4yn9hu-arALz5
Old Dec 21, 2017 | 08:00 PM
Evan_P's Avatar
Evan_P
You don't have to completely disable TPMS. With the Ford IDD you can change to pressure the module sees as normal in programmable parameters. I believe your 2012 is included. Might not hurt to call your local dealer and ask. I do it quiet frequently as there are a lot of lifted trucks around here.
Old Dec 21, 2017 | 08:46 PM
nickpohlaandp
Thank you again
Old Dec 21, 2017 | 08:49 PM
nickpohlaandp
I called the local stealership and they said they won’t do it for insurance reasons. I was wrong earlier when I said 50 psi. I checked them tonight and they were at 60. I pumped them up to 75. I’ll drive it like that for a few days and if I don’t like it I’ll get the FORScan stuff and change it.
fmuguira
Oct 1, 2017 03:49 PM
Cdashner
6.7L Power Stroke Diesel
Nov 3, 2014 08:50 PM
TheCurtster
Mar 15, 2014 05:06 PM
Jimmy Dean
2009 - 2014 F150
16
Dec 14, 2011 07:07 PM
wildlifer
23
Sep 11, 2009 07:35 AM
