E4od / ZF5 speed swap question
Old Dec 20, 2017 | 11:40 AM
95WorkHorse's Avatar
95WorkHorse
I recently did a e40d / zf5 speed swap on my 97 PS and can't find a factory wire harness for the zf5 back up lights and t-case plug. Is it possible to use the auto harness and if so what are the correct wire colors for the back up lights? Thanks.
Old Dec 20, 2017 | 12:03 PM
Briansshop's Avatar
Briansshop
Can get this for ya later when home if no one gets before.
Old Dec 20, 2017 | 12:46 PM
95WorkHorse
Thank you that would be awesome.
Old Dec 20, 2017 | 01:10 PM
jas88's Avatar
jas88
You would need the correct plug to fit the ZF backup-light switch but it can be done. The wires you want are on the neutral safety switch plug from the E4OD. On my ZF there is a dark green wire and a dark green wire with a red stripe, but not sure if that is the same colors on the E4OD harness or not.
Old Dec 20, 2017 | 01:31 PM
95WorkHorse
Ok thanks for the info I'll have to check it out after work.
Msword
Feb 23, 2022 12:31 AM
ssn2197
Aug 3, 2011 11:11 PM
tex4431
Aug 2, 2008 10:31 AM
jackedupford666
Aug 14, 2007 10:35 AM
samhihn
Aug 2, 2002 05:47 AM
