Just wondering if anyone has an update on this? My 2019 DRW F-350 Plat 6.7 is doing it as well. Dealer at first thought it was the transmission pump and pulled the trans... Of course, it did not solve the problem. (But may have solved an unrelated problem, so... silver lining???)
Anyways, I was finally able to pin it down to something steering related as well, just as described above. Would like to know if there is a solution on this.
Thanks gents!
The lack of responses has me believing that a solution has not been found. I have tried the dealer route with limited success. I might just have to live with it for now...
Mine is doing this as well. It sounds like it's coming from the steering column when I put my ear close to it. Turning the steering wheel silences it temporarily (6.2L / 2018)
I know this thread died awhile ago, but I’ve been looking around here and haven’t found anyone that’s had a solution or even the same problem with the same year... any update on this? I’ve been having this problem for a week now, super annoying... my 4x4 also stopped engaging... guessing vacuum leak somewhere but didn’t know if anyone found a solution.
Found a few interesting things for people hearing a whistle. 2 options for TSBs depending on the noise you are hearing
Loud whistle noise from under hood: (could be hearing through the dash)
From the dash but more of whine noise:
I hope one of these helps. I was just pissing around tonight and the whistle listed in the TSB clicked in my head and I remembered a thread about it.
