Disabling the Auto Start Stop
Old Dec 19, 2017 | 05:22 PM
vnleclaire's Avatar
vnleclaire
I have A 2017 F150 with A 3.5 ecoboost
Has anyone disabled the auto start stop feature using forscan? If so would disabling it void any factory warranty?
I really don't like the auto start stop feature on my truck I'm sure that others feel the same as I do. It seems to me that the extra wear on the starter and battery would out weight any saving that you might get in fuel.
Old Dec 19, 2017 | 05:27 PM
JKBrad's Avatar
JKBrad
You can do it through Forscan. It won't void your warranty. Any changes you make via Forscan will be over written if the dealer has to reflash you BCM for any reason, so write the values you change down for reference somewhere.
BCM module - 726-48-02 / x0xx/xxxx/xxxx) for 'auto start/stop'
Or you can do this
Or this, go to the 3:08 mark
Old Dec 20, 2017 | 03:33 PM
storage_man's Avatar
storage_man
I really don't like the auto start stop feature on my truck I'm sure other feel the same as I do. It seems to me that the extra wear on the starter and battery would out weight any saving that you might get in fuel.
What JKBrad stated and linked is 100% correct. Forscan can set it permanently off, so can the hot wire switch. For me I really believe Ford should of provided a REAL ON/OFF switch.
I really thought I could get used to the engine turning off at stop lights. But after 2 months of trying, every time it did it, I thought that "I now need to push this truck off the road, because the engine DIED". Its worse with me since I'm an old guy and I would need help to push this truck. SO with that, I used Forscan to turn it off. Today I like my truck a bunch better than before. Yes I know that an upgrade the computer code, will remove my forscan changes. I'll just have to do it again.
Old Dec 20, 2017 | 03:36 PM
F250GH's Avatar
F250GH
I've had the truck for one day, and already hate that feature.
Old Dec 21, 2017 | 08:34 AM
jimmy-six's Avatar
jimmy-six
I push the button Everytime I get in...old guy too.
Old Dec 21, 2017 | 01:51 PM
storage_man
Do you use POSTIT notes on the dash to remind yourself ? I just could never remember to do until it happens.
Old Dec 24, 2017 | 07:58 AM
johndeerefarmer's Avatar
johndeerefarmer
Mine is tuned by 5 star. No stupid auto start/stop feature and I have more power and it shifts better
Old Dec 24, 2017 | 09:38 AM
vnleclaire's Avatar
vnleclaire
Im not familiar with 5 star. Could you provide us with more information.
Thanks
Old Dec 24, 2017 | 02:17 PM
storage_man
Thanks
Here you go Custom Dynomometer Chassis Tuning Products and Services - 5 Star Tuning
Enjoy !
Old Dec 25, 2017 | 05:36 AM
Excelerater's Avatar
Excelerater
the amount of gas savings with this feature that no one wants is not even measurable
Old Dec 26, 2017 | 01:28 PM
johndeerefarmer
Thanks
5 star tuning does custom tunes. They give you more power, better shifting and disable the auto start/stop feature
Old Dec 27, 2017 | 12:27 AM
Komet86's Avatar
Komet86
I disagree, when I do a lot of around town driving it saves me a lot of gas. But .....only if my truck is warm or its not too hot outside or my phone isn't charging or if I move the steering wheel or for some other reason it decides to keep running. Lol
But another work around is to use tow/haul mode or sport mode also disables auto start stop. I find the standard shifting point lug the 3.5 EB quite a bit since I carry at least 1500 lbs of tools around most of the time. I use tow haul a lot to keep it shifting tighter, power is there quicker to accelerate and it's better for the hilly town where I live with better hold back. Sorry to detour.
Old Dec 27, 2017 | 08:26 AM
shortride's Avatar
shortride
I'm sure users are getting what they want out a tuner, and that's great but with a new truck still under the factory warranty I don't want to take that risk. If I had a truck that has an expired factory warranty and I wanted a few performance enhancements, that would be a difference situation all together.
Old Dec 27, 2017 | 08:35 AM
2020's Avatar
2020
I know it's hard on us old guys. I work for Paccar at a Kenworth truck plant and there is a lot of work that goes on before new features are introduced. Yea, it's true some of them don't pan out in everyday use. I'm starting to get used to it but I don't do very much city driving.
Old Jan 13, 2018 | 06:02 PM
dambird's Avatar
dambird
engine stop start. pigtail a four flat connector under the bumper, use some magnetic towing lights and put them by the frame rails or wherever. paint the lens black. your truck thinks you have a trailer hooked up and no more stop start.
