Coolant leak from...?
Old Dec 17, 2017 | 09:25 PM
'74 Ford 250 CS's Avatar
'74 Ford 250 CS
Noticed some coolant leaking on to the power steering cooler line. I've taken some pictures but I may have describe since I really can't tell where it's coming from and the pictures aren't the best. My question - is the pump attached to the front timing cover only? When looking at the pics from the bottom it seems like it connects to the engine therefore leaking around the pump seal. But when looking from engine bay i can see the separation between the pump and timing cover. Attachment 253050Attachment 253049
The drip is coming down below the red wire on one picture and the other you can see where it's wet behind the wire loom. Is it common that the seal fails?
Old Dec 18, 2017 | 07:46 AM
madpogue's Avatar
madpogue
Pics aren't working.
Old Dec 18, 2017 | 10:13 AM
'74 Ford 250 CS
Let's try this
Old Dec 18, 2017 | 02:41 PM
Jarrett Campbell's Avatar
Jarrett Campbell
So either freeze plug, water pump, or hose.... There's a freeze plug on the front of the head that could be bad or the hose on the front of the head could be leaking. Clean it up real good and see where the coolant is coming from
Old Dec 18, 2017 | 03:37 PM
'74 Ford 250 CS
I had checked the hoses, so I don't feel it's related, but I review again. Didn't know a freeze plug could go bad. It's been cold here, but wouldn't feel like my coolant concentration would be off to freeze.
Old Dec 18, 2017 | 08:59 PM
Bluediesel250's Avatar
Bluediesel250
Pop the fan belt off and grab the fan to check for up and down or side to side movement
Old Dec 18, 2017 | 09:10 PM
z31freakify's Avatar
z31freakify
Its probably just your water pump gasket not sealing, specially now that it started to get cold, the gaskets shrink with the cold.
Shawn MacAnanny
Jan 30, 2016 06:39 PM
tomboy67
1983 - 2012 Ranger & B-Series
Apr 5, 2015 01:21 PM
Shake-N-Bake
Mar 9, 2010 11:59 PM
masterc16
Jan 11, 2007 09:41 PM
gearheadz80
3.8 & 4.2L V6
Nov 17, 2005 11:26 AM
