Need some help quick
Old Dec 17, 2017 | 10:53 AM
jwitty's Avatar
jwitty
So I'm going or be picking up my 66 f100 in a couple hours. I just wanted to know where to find vin and any other numbers on the truck. I just want to compare it to the title to make sure they match. Thanks
Old Dec 17, 2017 | 11:04 AM
TA455HO's Avatar
TA455HO
Lead Gopher
All three of my trucks have it stamped on the top of the passengers side frame rail about even with the alternator. Make sure you have some solvent and maybe something like a brass bristle brush to clean the area and you should be able to locate it. This stamping begins and ends with stars
*F10XXXXXXXX*
You should also find the warranty plate on the left drivers door below the latch. I like to verify the door plate matches the frame and matches the title. The door can be changed and sometimes people forget to move the Warranty plate from the original door so the frame is the important one.
Chad
Old Dec 17, 2017 | 11:06 AM
jwitty's Avatar
jwitty
Alright so the frame one is the most important then? So it isn't hard to find then right?
Old Dec 18, 2017 | 09:12 AM
Bert65's Avatar
Bert65
the frame one is the most important. many times doors get replaced and the prior owner does not replace the door tag onto the replacement door.
is it hard to find?
my 65 was a little tough to locate. mine was there but faint and under a layer of dirt, light rust etc.
As prior post, you will need a wire brush and some type of solvent to get to the pure metal. to see it.
Old Dec 18, 2017 | 09:15 AM
jwitty's Avatar
jwitty
Well the numbers do match. Picked it up and now getting it running again. Thanks guys!
Old Dec 19, 2017 | 06:14 AM
vze2c2gb's Avatar
vze2c2gb
Good luck and post some pics
Jbkurtzer
Jul 21, 2015 08:07 AM
ehug21
May 18, 2014 10:07 PM
emeraldcoupe
Jan 12, 2010 02:19 PM
69 F100 4x4
Paint & Bodywork
Jan 7, 2002 08:07 PM
